Jake, we had one on my nephew's car. We even had a crank trigger squeezed in there. It was super close, but it didn't hit. Installing that ATI unit is a real PITA. The damper bolt is about 1/2 mile into the hub
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by RacerX70CC
The above referenced part number (917274) is 7.5"
I realize that. That's the steel shell damper, 9.75 lbs, 7.5" OD with steel hub @ 2.9 lbs.
917269 is an aluminum shell damper, 6.75 lbs, 7.5" OD with a steel hub @ 2.9 lbs.
917275 is the one I have, aluminum shell damper, 4.5 lbs, 6.78" OD and with a steel hub @ 2.9 lbs.
This same unit is also available with an aluminum hub by ordering 917273. The aluminum hub is only 1.4 lbs.
I opted for the steel hub version thinking it better for a street car with full accessories.
I've posted all of this because questions re/ the Y body Super Damper have come up frequently here as of late. For reasons such as mentioned by Jake, I recommend the small damper. Not does it also provide maximum clearance and slightly underdrives the accessories, but it's good to 600 HP. This should cover most of us.
are you talking about not having that much clearance from the front face of the damper to the steering rack. If it is too close then check your hub and make sure it's bottomed out. I run the blower version which is 7.35" in diameter but should be fairly similar otherwise since the blower ribs are on the back side.
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Jake,
I too use the 275 ATI model 6 7/8" super damper as well on my 95. I currently own two of these dampers and they are both about 1/2 to 9/16 inch away from the steering rack on the face dimension and only about 1/4" after the three damper face bolts are installed. ATI says these bolts have to be installed. Yes, it's close but I have never had a problem except when installing the engine. It doesn't give you alot of room to squeeze by the steering rack but it will go.I also use the crank spacer required by the directions for 95. The only problem I had with the second damper I bought was it had a different style bolt head that goes in the 3 hole face. It was a star head style bolt which stuck out about 3/8" reducing rack clearance. The first damper I purchased had a round head allen head style which stuck out 1/4 inch so I swapped them to regain my 1/4" to 5/16" minimum clearance and all is well. You might want to find some shorter round headed bolts if this is your problem. The shell face itself should be about 1/2" to 9/16" from the rack as stated earlier when installed.
Rick
I was concerned about the closeness of the FACE of the damper to the steering rack. Mine doesn't touch and I've got about 1/4" clearance between the rack and the three largest bolts on the damper. I was just wondering if that's what others are seeing.
I found that the new bolts on the damper call for a T-40 PLUS. Trying to find one locally didn't work out. I went to about every store I could think of a no one ever even heard of it. Ended up buying one from Summit. 918997 I believe it is.
Yes, I have one on my '96. The clearance from the face to the rack is very tight. In fact while roadracing with racing brake pads the damper bolts were actually hitting the rack under very heavy braking. I ended up having to grind the heads of the bolts down slightly.
That's what I suspected, that mine is installed correctly, but, by design, the damper sits very close to the rack.
When I was pressing on the hub, I actually unbolted the timing chain cover just so I could make absolutely sure I'd pressed it on all the way.
I'm looking for the underdive damper at 6.78". How much of a difference would having the lighter aluminum hub make? What is the advantage to having the steel hub in a street car with full accessories? Mine is a daily driven street/track car that will eventually get a 396 bottom. Are those the correct part numbers for a 95?
