L98 Drag Racing 101
yes, keep OD off!
Have you ever launched the car on the street to where the tires spin? Thats what you DON'T want. Since the tracks are usually pretty level, once you stage, you can let off the brake. Keep the clutch all the way in and rev it up to, say, 1200RPM (or whatever you feel comfortable with). Once the light goes green, let the clutch out, and see if she spins, if not, then mash the gash to the floor. The launch is really all about how YOU are able to drive YOUR car... and the traction it has (tires and track prep) and a few other factors. Just keep making runs until you have it down.
Shift points are different for each car. I usually shift mine around the top of the tach's curve or just a tad before. You can experiment around with this to find the best place. I can't recall the RPM I run, but it doesn't matter because I have a 6spd and you haev a 4+3.
You can find your gearing by looking under the arm rest cover at the RPO codes. Just google search Corvette RPO codes and you can look at the list to see which codes refer to the gears, then figure it out from there.
Some things that will help times.... take out the spare tire and any other heavy crap you have in the car.
Run the gas tank down to just enough to get to the track and back, or leave enough to get to a gas station on the way home. Try to stay under 1/4 tank.
Make sure you have the AC turned OFF when you run down the track (the compressor robs HP).
Other than that, just have fun. Don't be embarrassed to run high times at first, remember you are out there to have FUN. Lower times come with practice. Once you master it, and if you really get into it, start modding it. Theres many cheap mods that can get some nice HP gains that won't hurt the car's daily drive-ability or gas milage.
You will only run worse ETs if you shift higher than that. I was able to run a 14.02 that day and trapped at 95.1 mph. I tried shifting it higher like at 5000 and I ran a 14.6. The motor didn't feel like it was making anymore power up there. Just more noise.
I did the same thing and my best was 14.2 @ 95 mph. Some good advice there.
Yea it's nice to know how fast it is, but you should be doing road courses instead of straight line.
You have very stiff springs and sway bars for that. For a drag car, your shocks are all wrong, and the weight distribution is poor. The car needs sticky tires to launch, and If you launch that hard, the trans or clutch is gonna blow.
I am not saying gloom and doom, but your car is 23 years old, and rubber bushings, shocks, springs, mounts, all the soft goods are the same age, and aging.
The trans is readily available, but it's a pita to change. so is the clutch. I don't know anything about you or your car, and I hope it hangs together. but to me, it's a shame not to do the twisties with a car that begs to kick asphalt in the face of porsches, mustangs, camaros, jaguars, and other legendary corner carvers.
just my 2c
Drive around the water box, do not get the rear tires wet.
Drop the clutch and spin the wheels, very briefly, only a few revolutions, just enough to clean them off. Hot/smoking street tires do not grip.
Pull up to the staging lights quickly and get pre-staged. Get staged when the other guy starts pulling up. This will give you PLENTY of time to concentrate on holding your launch rpm and watching the third yellow. Hold the clutch in and rpms at about 2000 rpm. This will vary depending on the traction available and how grippy your tires are. If they're old, they won't grip for sh** and you'll soon realize racing on cheap/old tires is a waste of time.
Let off the clutch quickly at half throttle and quickly go to full throttle, if you get wheel spin, modulate the throttle a bit to try and get it back.
Shift at 4200-4300. Keep in mind the tach lags especially in 1st gear, so pay attention to the engine pitch as well.
Make damn sure you don't let off before the finish lights, some people do. There's plenty of shut-down room so stay in it until you're absolutely sure.
You'll probably spin the tires on launch nearly every time on your first trip out. If you spin em at 2200 rpm on your first launch, and you're smart, you'll adjust and drop it from 1500 rpm. Then when you bog the engine down, drop the clutch from 2000 rpm... until you narrow in on the window.
Expect 2.20 60' on a poorly prepped track with street tires. With that launch, I'd expect about 14.3-14.5 1/4 et at 96 mph.
You will find out there is a sweet spot. Too much gas, and the tires will spin up, and not enough rpm's, and the motor will bog. This is how it goes with my car. To compare when my 88 was stock I went to the track for a few runs. The best was a 14.21@98.5 with I believe a 2.05 60 foot. Goodluck!
This might be hard to do, but try shifting at 4300 the whole way down the 1/4 mile, then bring it up to 4500, and then finally too 4700, and then compare your times. I believe my 98.5 MPH trap speed was shifting at 4500.
As far as shifting my 4+3, It felt best shifting at around 5000 on the stock tach. This may be slightly higher because I have a TPIS big mouth, but I have always felt that it's faster when you error on the high side.
Be careful not to get wheel hop, as that is what kills transmissions. With my h/c l98, that 2.1 60" got me a 13.3 @ 106mph. Doesn't seem to be much to gain with the TPI intake, but I may go back some day with some drag radials just to pull that 12 second slip.
The tach is slow to respond, so if you shift when it says 4200-4300, you'll already be closer to 4500, which is ideal, IMO.
I put in a shift light for this reason, because the tach is worthless, especially in 1st gear, I think I have it set at 4500 rpm right now.
Don't be a noob and spin the tires every time out. Experiment, spin them once, ease up and bog it the next time out, and narrow in on that sweet spot where you get a little squeal from the tires without bogging it or breaking loose.
Staging. You don't stage at the tree, it's actually about 30 feet behind the tree. There are 2 light beams about 6 inches apart running on the ground. When you break the first beam with the front tire, the top light on the tree will light up. Creep forward until the second bulb on the tree lights up, that means you've broken the second beam. Once you and your opponent have done this, the amber lights will begin to light in sequence down to the green.
The finish line. My first time at the track, I let out at the 1000 foot mark, 320 feet shy of the finish line. The 1/4 mile stripe is quite aways out there.
The return road. If the road at the end of the track that brings you back to the pits is on the left, the car in the left lane should always exit first. If you are in the right lane, and are much faster than the car in the left lane, use your brakes and slow down to wait for him. Come to a stop if you have to. Never pull in front of a moving car to exit the track. Always wait if you are in the far lane and must cross traffic to get to the return road. Conversely, if you are in the near lane, be aware that not everyone knows this little jewel of information, and they may turn in front of you at any time.
Have a good time man, we were all new once.
Good info!
What tires are you using and how old are they?
I think the "run it 80%" is bad advice. Maybe for some monster build up the first trip out, but not for a stock vette. Go all out, you don't want to waste a run.
