Thunk-tastic! (Insight needed)
Old Jun 27, 2007 | 10:11 PM
TorchRedRob's Avatar
TorchRedRob
Default Thunk-tastic! (Insight needed)
Just wanted to get some insight about a problem I'll be looking at this weekend. The front end has just started to make a thunk sound. Only happens over abrupt changes in pavement height (higher to lower), big bumps, or occaisionally on quick throttle application while cruising.
I have already checked the stuff I can see without getting under it: LCA bolts, UCA bolts, ball joints, shocks, spring retainers, tie rods, anti-roll bars.
Once I can find the time to put it on stands, I'll take a look at motor mounts, drivetrain components, and other suspension components.
Any thoughts about other stuff I should check or what might be a likely culprit?
Old Jun 27, 2007 | 11:11 PM
chucks88's Avatar
chucks88
How old are your shocks?
Old Jun 28, 2007 | 10:50 AM
TorchRedRob
to my knowledge they are probably the originals, so about 12 years.
Old Jun 28, 2007 | 11:12 AM
Bob CTS's Avatar
Bob CTS
Check the spring also.
To Thunk-tastic! (Insight needed)
