What Length PushRods?
Old Jun 28, 2007 | 05:18 PM
JAKE's Avatar
JAKE
Default What Length PushRods?
Just want to get an idea of the length pushrods you guys/gals have moved to when modding your engines.
Mods like reduced base circle camshafts, decking block, thicker/thinner head gaskets, cylinder head change, etc.
Thanks,
Jake
Old Jun 28, 2007 | 05:51 PM
Pete K's Avatar
Pete K
Jake,
You will likely be somewhere between 7.100 and 7.400.
Too wide of a spread to guess. Trust no ones opinion. Check it with an adjustable pushrod checker and a checker spring.
Old Jun 28, 2007 | 06:43 PM
JAKE's Avatar
JAKE
Right. I measured mine with an adjustable pushrod checker and ordered the length I need. Preload's set and new engine's in the car now.
I was just wondering what lengths other guys are using; just for my information/curiousity.
Jake
Old Jun 28, 2007 | 07:33 PM
STL94LT1's Avatar
STL94LT1
605/622 lift camshaft, Imp SS head gaskets, .050 longer valve stems, and I'm still running the stock pushrod length.
Old Jun 28, 2007 | 07:44 PM
LD85's Avatar
LD85
I can mail you my adjustable push rod checker if you have time to wait 2-3 days, PM me if you want
Old Jun 28, 2007 | 09:58 PM
Pete K's Avatar
Pete K
Jake
My L-98 uses 7.200
My 406 with retro fit roller cam uses 7.150
Old Jun 28, 2007 | 10:07 PM
JackDidley's Avatar
JackDidley
My L98 with a ZZ4 uses 7.3. I also have aftermarket heads that are milled .030 so that comes into it. I guess there is no standard combo.
Old Jun 28, 2007 | 10:49 PM
aboatguy's Avatar
aboatguy
I ended up with 7.15s but on a friends LT1 it was 6.9X.
Mike
To What Length PushRods?
