crankshaft thread specs???
Old Oct 29, 2001 | 09:31 AM
johndezman's Avatar
johndezman
Default crankshaft thread specs???
does anyone know the specs so i can make a harmonic balancer install tool?
Old Oct 30, 2001 | 09:03 AM
johndezman's Avatar
johndezman
Default Re: crankshaft thread specs??? (johndezman)
ttt
Old Oct 30, 2001 | 12:50 PM
MarkBychowski's Avatar
MarkBychowski
Not sure on the exact specs, but there IS a difference between the older SBC and newer SBC crank threads. Newer ones are metric, older ones are standard. I know because I tried using a older style bolt in my LT4 crank and it's a hair too small. I'm not sure when they changed from std to metric.
Old Oct 30, 2001 | 05:18 PM
johndezman's Avatar
johndezman
i'm interested in the mid 80"s style
thanks for your help
Old Oct 31, 2001 | 04:23 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I used a threaded rod to go into the crankshaft and a collection of nuts and washers to push the balancer on the crankshaft. I thought the crankshaft bolt was still english. Take the harmonic balancer bolt to the hardware store and use some nuts to figure out the size of the threads.
To crankshaft thread specs???
