Heads Question
Old Jul 1, 2007 | 01:17 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
Default Heads Question
The valve seals on my 85 4+3 (72k) are leaking. I am replacing the exhaust with headers on back soon. I also have a set of '86 aluminum heads in my basement. I am having the plenum ported, too.
Question:
Would it be significantly more expensive to change the heads? or should I just have the valve seals replaced?
I am not capable of doing this myself. I figure that the exhaust is already detatched, the plenum is off... Now would be the least expensive time to change the heads, otherwise I'm selling the aluminum heads.
Lastly: I have the '86 valve covers, too.
Old Jul 1, 2007 | 02:02 PM
tjwong's Avatar
tjwong
Question:
If you have the intake off, and the headers off. You are an hour away from removing the heads. All you need is a set of head gaskets and if you wanted to splurge a set of new head bolts.
Old Jul 1, 2007 | 03:11 PM
aboatguy's Avatar
aboatguy
Install your aluminum heads.
Old Jul 1, 2007 | 06:10 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Have them ported first then put on aluminum and replace the rockers with full rollers.
Old Jul 1, 2007 | 06:38 PM
williammackean
St. Jude Donor '07
I am not sure if the intake needs to come off or not. The plenum will be off, and maybe the fuel rail if I swap the injectors. Still, the extra time will prolly be worth it.
I'll ask my guy if he thinks porting is worth the $$. I think it would be, but he is famous for telling me not to bother with some things.
He'll also be replacing the oil pan gasket & seals. Prolly hit the knock sensor & connector while we're there. They got coated pretty well when the vc gasket went last year.
Aluminum chamber vs iron chamber: 64cc vs 176? Am I right?
How much would full roller rockers run me?
Thanks!
Old Jul 1, 2007 | 07:10 PM
CFI-EFI's Avatar
CFI-EFI
Iron heads, 76 cc combustion chambers. 128 or 113 aluminum heads, 58 cc combustion chambers. That will give you something over 11:1 compression ratio, with no other changes. If you plan to use the EGR, don't forget the EGR tube and the '86 intake manifold base. The aluminum heads don't have the exhaust passages for the EGR gases.
RACE ON!!!
Old Jul 1, 2007 | 07:21 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Old Jul 2, 2007 | 01:49 AM
williammackean
St. Jude Donor '07
Originally Posted by Corvette Kid
Meaning that one can replace the seals with the heads attached, so I'm not sure it's worth the $$ for removing the intake and such.
Oh, and I do have an '86 intake, too. I'll hafta search for the bennies of keeping/ditching the EGR. Anyone care to point a guy in the right direction?
To Heads Question
