A/C and Air Pump delete
Old Oct 27, 2017 | 07:21 PM
littleredcorvette88's Avatar
littleredcorvette88
Hi emo-vet
What did you end up doing for the delete? I have a 91 and would like to do the delete. Since this is such an old post the links no longer work for the info I need.
Did you swap out the tensioner pulley for a grooved one? If so do you remember the model #
What model belt did you get?
I'm running the smog pump delete pulley/bracket already...not sure if that would effect the belt length
Any Info would be great!
Old Oct 29, 2017 | 06:10 AM
Schieby's Avatar
Schieby
Hi,
I deleted the AIR pump, AC and belt tensioner at the same time. You don´t need those shitty AIR delete pulleys. You need a new, shorter belt, old school DIY alternator bracket with a slot to get tension. That´s all.....
Now everyone will tell you that won´t work, ´cause the water pump runs backwards. My 85 doesn´t care for over 3 years
....no cooling issues, even in heavy traffic , on the german Autobahn or on the dragstrip wit a 150 hp nitrous shot.
You see the DIY alternator bracket in the 1 o`clock position, can shoot more specific pics.....german backyard engeneering
Old Oct 29, 2017 | 07:04 AM
Erik Schiebek's Avatar
Erik Schiebek
1st Gear
....her is another pic.....
Old Dec 27, 2017 | 07:45 AM
Mat85kart's Avatar
Mat85kart
2nd Gear
Default Alternator bracket
Hey guys, first time here! I just bought a 85 trashed vette and i'm doiing a roadkill vettekart style rig! Just done the a/c and smog pump delete, and was looking for the best solution. Think i'll go with the last one, the old school slutted bracket. I will also take a reverse water pump juste to be sure, enyway it's just 30$ on rockauto. I'll send picture when done. Thanks
Old Feb 24, 2019 | 03:46 PM
anthony Laughlin's Avatar
anthony Laughlin
1st Gear
Default When I do my ac delete on my 89 what do I do with all the wires?
I have a 1989 corvette and have dun a lot under the hood but I don't know too muck myself because I had help but there where a lot of loose wires after what do I do with those
Old Feb 24, 2019 | 07:42 PM
BLKMAMBA's Avatar
BLKMAMBA
https://www.tpis.com/parts/view/62
Old Jul 4, 2021 | 07:27 PM
Socalsalas's Avatar
Socalsalas
Default My AC delete
I have a 94 base model. Removed all AC lines, condenser, accumulator, and compressor (TPIS bypass pulley). I left the blower and rvap/heater core so I could still use my defroster and interior fans.
What can I use to cover the AC inlet line ends leading to, and from, the evap/heater core?
Old Oct 17, 2022 | 09:07 PM
sturmmorser2000's Avatar
sturmmorser2000
What size belt are you using? Is the water pump pulley original cant tell from the pic?
Old Oct 18, 2022 | 11:23 AM
Socalsalas's Avatar
Socalsalas
I cant remember the size of the belt, but it was whatever the FSM recomended. The water pump pulley was replaced when i replaced the water pump a few years ago. And i actually misunderstood about the air pump, which is for an earlier model than my 94.
I did end up buying the FSM and deleting all AC components succesfully though, dont need it where i live anyway theres a lot more room to work in there now, and the replacement pulley looks great in there. Plus, there is a noticeable difference in power I'd say below 40 mph
