Problem accelerating when engine is warmed up
Old Jul 9, 2007 | 09:33 PM
mseven's Avatar
mseven
Originally Posted by 91sTeal
I hope the FIs are the same stock size, do not want to mess with the ECM/PCM at this point.
get the part number and cross check w/the mfg. for #rating. While you're looking at it, make sure all of them have the same # that would answer these questions at least. Sooner or later at this rate of replacing parts the "wrench" may get lucky (I do hope so for your sake) HOWEVER, it sounds like you may have to go down there and rescue this car.
Old Jul 10, 2007 | 01:14 AM
Sam Lam's Avatar
Sam Lam
91sTeal: after reading your posts concernind the service tech, I am very pleased to do my own car/engine work. If I screw something up, I just go to a mirror and give the old boy in the glass a good **** chewing
Old Jul 14, 2007 | 02:54 PM
91sTeal's Avatar
91sTeal
Default Car Is Home !!!
Picked it up yesterday, and it is running really nice. The car does not idle bad and is real smooth on acceleration. It was the FIs, he replaced with 26lbs ones. I am so glad it is over time to drive her again
Thank you to all who provided input.
Tony
Old Jul 14, 2007 | 06:10 PM
Sam Lam's Avatar
Sam Lam
Tony: I recommend that you verify your mechanic installed 26 lb hr fuel injectors in your car! He should have installed 22 or perhaps 24 pounders. If he did install 26 pounders in your car (and you do not have an adjustable fuel pressure regulator), you will probably have problems passing emissions testing. Your car will be running "rich" due to too much fuel being injected into the cylinders. Do you know anyone with a scan tool to check the BLM values? Sorry for the bad news on this as I know you have BEEN through hell with the FIs in your car.
Old Jul 14, 2007 | 06:27 PM
KeyWestJack's Avatar
KeyWestJack
Old Jul 15, 2007 | 10:23 AM
91sTeal's Avatar
91sTeal
Yeah I do know someone with a scan tool. Thanks for the tip, I will have to get that checked out. Man I thought the drama was over !!
