code 33
Old Jul 3, 2007 | 10:53 AM
ridgevette's Avatar
ridgevette
Cruising
Default code 33
Hi, I followed the diagnostic procedure in the shop manual and it led me to the conclusion that the burn off module requires replacement. Does anyone have any experience with this and is this process acurate or in other words highly reliable (ie replace the module)?
Old Jul 3, 2007 | 11:33 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
both relays modules are the same, NAPA $11 ea, replace both at the same time... thats all there is to it...
Old Jul 3, 2007 | 12:37 PM
80sRule's Avatar
80sRule
According to his other post he has an 85, which has a unique burn off module that is pricey.
Old Jul 3, 2007 | 03:38 PM
ridgevette's Avatar
ridgevette
Cruising
Default code 33
Yes, I have an '85 and it is expensive, hence the question. Just want to be sure. Thanks
Old Jul 3, 2007 | 07:27 PM
emo-vet's Avatar
emo-vet
sorry to but in on your thread, but is a code 33 a M.A.P problem please?
i have had a code 33 for some time now and i replaced the m.a.p and still have the same problem,code 33.
i saw you mentioned the burn off module?
where is this located and what is its job please of doing ?
basically is it some sort of relay is it ?
i have a 1991 vette if that helps locating it.
thank you
regards
shae
Old Jul 3, 2007 | 11:19 PM
ridgevette's Avatar
ridgevette
Cruising
Default code 33
you will probably get someone more experienced than myself responding, however, I will take a stab at it. My car is an 85, which contains a MAF sensor and a burn-off relay or module. 86 to 89 was basically the same except the burn-off function is in the ECM and the relays are in the engine compartement roughly on the firewall behind the battery (above). I believe from 90 on in the C4's the system was changed to a MAP sensor. Probably the same issue. I used the factory shop manual to diagnose this, these are great!. Recommend you locate a manual or someone with it.
To code 33
