cross-fire
Old Jul 3, 2007 | 05:46 PM
devilfish's Avatar
devilfish
Default cross-fire
is it "usual" to get "cross-fire" if your plugwires are tight togheter?
I try to find a little missfire during low rpm driving.
Old Jul 3, 2007 | 06:00 PM
jhammons01's Avatar
jhammons01
I had to finally upgrade to the 8mm plug wires to get the "rough" Idle out. Now things are smooth especially at the low rpms.
One made mention of the Stock Guides for the wires needing to be in place. I Questioned further (like you) but got no response from him or the rest of the forum.
I'd like to know, I have mine zip tied to the Metal tabs on the Valve covers where the plastic guides should be.
Old Jul 3, 2007 | 08:55 PM
CFI-EFI's Avatar
CFI-EFI
The stock wires are 8 mm. They have been, in GM cars for many years, as long as the HEI has been used (mid '70's?).
When two secondary ignition wires are close together, running parallel to each other, the current from one wire can induce a current into adjacent wire. Spark plug wires should never be bundled with wire ties, holding them close together. Even properly separated in wire looms, plug wires shouldn't run parallel for much distance. When wires have to cross, they should cross as close to a 90° angle as possible.
RACE ON!!!
Old Jul 3, 2007 | 10:13 PM
jhammons01's Avatar
jhammons01
Very Interesting......
And I am not sure what size, Maybe be bigger, hows that? I know they were bigger than what came off. ( I looked around the Garage but I don't see the invoice, so I can't verify the number for sure)
Now, to the plastic spacers, can you give us a good idea where to find new ones?
Old Jul 4, 2007 | 01:06 AM
C4boy's Avatar
C4boy
Ecklers used to have the original wire looms that pop on to the metal tabs. They're probably $39.99 each, but that's the only place I've seen them.
Old Jul 4, 2007 | 01:58 AM
zach540's Avatar
zach540
On my LT1, granted, it's in a 4Runner, I'm using part number MFY-5035613, they're $45 from summit and bolt nicely to the center bolt on the valve covers.
Old Jul 4, 2007 | 02:12 AM
GRX's Avatar
GRX
Wow Zach540! An LT1 in a 4Runner. I have a 4Runner too. Are you in CA?
Old Jul 4, 2007 | 02:15 AM
zach540's Avatar
zach540
No, I'm living in SD for the time being, until the military wants to relocate me to another base
Old Jul 4, 2007 | 11:18 AM
devilfish's Avatar
devilfish
RACE ON!!!
I tried to seperate all the wires today as much as i could. Its a huge improvement. No more tiny popps in the exhaust during low rpm operations.
Im just curios as I got now missfire at high RPM. I pull this baby to 6500 with no hesitation what so ever. Its just during low rpm, where I could hear tiny popps in the exuahst ( like unclean combustion ). And the car bucked a bit from time to time. Whery strange..?
Its not 100% good thou. Its now like 90% good. I still have some tiny bucking/jerking at low rpm. But perhaps that is in the tune.
The exhaust note is much better thou.
Old Jul 4, 2007 | 11:27 AM
CFI-EFI's Avatar
CFI-EFI
That's fine. I can only respond to what you post.
It has been years, but when I needed new plastic wire holders that slide onto the factory brackets, I ordered them from a Chevy (ouch) dealer. Everybody and his brother has a wire holding/routing system. There is no limit to your possibilities. I wanted to use the stock set up.
RACE ON!!!
Old Jul 4, 2007 | 03:32 PM
devilfish's Avatar
devilfish
Any ide why this only show its ugly face at low rpm?
Old Jul 4, 2007 | 05:20 PM
Frizlefrak's Avatar
Frizlefrak
Not to hijack the thread, but.....
That LT1 4Runner is one of the coolest swaps I've ever seen. Please....start another thread with build up pics and details....
OK, back to the plug wire thread.....
Old Jul 5, 2007 | 03:15 AM
jhammons01's Avatar
jhammons01
oh, no worries here. I don't get mired in the minutia. I am only interested in the principle. I am happy you are spilling truth out all over the floor. I need it.
"Wire Looms" is that the proper name for these or, is that colloquial?
Old Jul 5, 2007 | 08:31 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Eckler's and MAM still carry the O.E.M. Packard wire retainers and separators.
They're like $10.99 plus shipping for the complete kit at MAM, not sure about Eckler's.
http://www.madvet.com/shop?frame=3.815
Old Jul 5, 2007 | 09:33 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I'm going to buy that Summit setup.
I totally removed the brackets on mine. I got sick of getting my fingers hacked up by them
Old Jul 5, 2007 | 01:19 PM
jhammons01's Avatar
jhammons01
Holy Snicky's the forum comes through again.
Thank you very much, this is just what is needed.
I'll order a set as soon as I post this
Old Jul 5, 2007 | 02:12 PM
onedef92's Avatar
onedef92
I'm going to order a set, too.
After replacing all the ingition wires on my car two weeks ago, I'm not in a hurry to walk through the LT-1 Driver's Side "Hellhole" any time soon and want to protect the new wires from touching any hot engine parts and protect them from chafing.
Old Jul 8, 2007 | 03:33 PM
jhammons01's Avatar
jhammons01
FEDEX: 374269271032635
That is the Tracking number for my wire holders. They'll be here soon
To cross-fire
