OK I am ignorant, what is a knock sensor?
Cruise-In II Veteran
Re: OK I am ignorant, what is a knock sensor? (blk91)
It listens for pinging and detonation and if any is detected the sensor reduces timing to combat it. I am not sure how bad the detonation has to be for a code to be tripped.
Also if you start your car with the temperature above 220 I believe the computer throws in a bunch of advanced timing to check the operation of the knock sensor. In other words it forces detonation to check it.
I do have a slight knock now... :mad
When does it knock..? All the time, just under load, under acceleration.
[Modified by Glock'94, 2:51 PM 10/29/2001]
Re: OK I am ignorant, what is a knock sensor? (C4 4Me)
