Ignition switch
Old Jul 4, 2007 | 12:09 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Default Ignition switch
Hey guys! I can't get my key out of the ignition switch. I took the switch out of the steering column and then I could remove the key. The problem seems to lie in the linkage for the reverse gear to actuate the tumbler. I've rammed the gear shift into reverse to no avail. Is the linkage adjustable? I've also had a problem with my clutch fluid leaking so air got into the system. As I can get the tranny into reverse (and drive it) I don't think the fluid is my problem with the key. I've also tried a new tumbler and had the same results. Any ideas?
Old Jul 4, 2007 | 08:06 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Park%...Adjustment.pdf
