Need help with headlight assembly
Old Jul 4, 2007 | 02:07 PM
davidsenna's Avatar
davidsenna
Cruising
Default Need help with headlight assembly
Hello, I did the typical repair with the brass gears on my 88 but I can't seem to get the driver's side light to work properly. No matter how I index the headlight before I put it in, it always runs opposite what it should. I turn the lights off and it pops up, turn them on and it closes. Any ideas? Thanks in advance for any help.
Old Jul 4, 2007 | 05:02 PM
bogus's Avatar
bogus
that's wierd.
did you have to disconnect the wiring? if so, you might have put the motor wires in backwards... that's my only thought.
Old Jul 4, 2007 | 08:56 PM
davidsenna's Avatar
davidsenna
Cruising
Originally Posted by bogus
that's wierd.
The wires can only go one way when clipped in. I did check that thinking it made perfect sense. Thanks for the reply.
Old Jul 5, 2007 | 08:40 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I wonder if your headlight motor relay has gone bad? That's the only thing I can think to add.
Old Jul 6, 2007 | 04:20 PM
davidsenna's Avatar
davidsenna
Cruising
Thanks for the suggestion!
Old Jul 6, 2007 | 07:10 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Verify the linkage is hooked up properly.
Manually turn the **** on top of the headlight motor counter clock wise. The headlight bucket should open.
Turning the **** clockwise should close the headlight bucket. The **** takes a lot of turning for the headlight bucket to move.
To Need help with headlight assembly
