performance injectors
Old Jul 5, 2007 | 02:55 AM
rolando4812's Avatar
rolando4812
Default performance injectors
i'm looking to replace the stock injectors in my L98 vette to revive it. i'm looking for a kick also, what are good performance injectors?
Old Jul 5, 2007 | 08:41 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Bosch type 22 lb injectors. Don't run higher on a stock or near stock motor.
Old Jul 5, 2007 | 11:28 AM
JAKE's Avatar
JAKE
Unless one or more of your injectors is not up to snuff, I don't expect you'll see a "kick" by installing new injectors.
Jake
Old Jul 5, 2007 | 11:40 AM
vader86's Avatar
vader86
For you to gain anything, you either have to have currently bad injectors or serious intake mods.
Otherwise it'll do nothing.
Old Jul 5, 2007 | 05:11 PM
rolando4812
i think my injectors are bad. i'm getting white smoke and delayed starts.
Old Jul 5, 2007 | 10:50 PM
BADDUCK's Avatar
BADDUCK
Check for coolant in the oil.
Old Jul 5, 2007 | 11:21 PM
JAKE's Avatar
JAKE
White smoke out the tail pipe can be coolant getting into the combustion chambers.
Borrow a pressure tester from AutoZone and test to see if the pressure holds. Best way to tell.
Jake
Old Jul 6, 2007 | 01:02 AM
Sam Lam's Avatar
Sam Lam
The best bet for your $$$ would be to remove the injectors and send them to Rich Jensen (Cruzin Performance) for cleaning and flow testing. You stock injectors have a good service record and placing more fuel in the cylinders (performance injectors???) does not make it go faster
Old Jul 6, 2007 | 02:06 AM
rolando4812
Jake
what would i be testing? and how. i'm seventeen and still learning more about car maintanence
Old Jul 6, 2007 | 12:32 PM
BADDUCK's Avatar
BADDUCK
the exhaust
To performance injectors
