Idle Problems, Maybe your IAC is bad.
Old Jun 18, 2008 | 08:56 PM
  #41
95wht6spd's Avatar
95wht6spd
I cleaned my MAF, TB, and IAC and it worked like a charm.
NO more dropped idle when I stop, now it stays high for a few seconds then drops down like before. Also I can run the AC when stopped and it maintains the idle. Side benefit is that I hardly have any rattling from my SM flywheel at idle now. Also it just seems crisper response, drives smoother especially at low speeds, no more bogging at take off. thanks!
Old Sep 1, 2008 | 01:24 PM
  #42
90Indy's Avatar
90Indy
Thanks guys, I checked my IAC as suggested. What I first noticed was the connector seemed to come off of the IAC very easy. I did not have to fight with the locking tab nor did I have to pull with any force to remove it. I went ahead and removed the IAC and checked it with a multi-tester. Pins A and B ohmed 65 and C and D ohmed 66. Everything else looked good so I put it all back together and made sure the connector was fully engaged and locked this time. Started the car and it idled great, just like it has since the rebuild.
I have concluded the only problem was the connector had somehow worked its way out of the IAC. Easy, cheap fix. However, I have learned something about the IAC so I guess it all worked out.
Thanks to all of you who posted ideas. My next hurtle is learning to datalog and tune.
90Indy
Old Sep 2, 2008 | 12:07 PM
  #43
bee674's Avatar
bee674
Originally Posted by JAKE
96 LT1
My new scanner arrived today and, guess what, it's telling me that the IAC isn't working either; no reading. On top of that, I'm not getting a MAF reading either.
All the other values are showing up real-time and there is no Check Engine code either stored or lit up.
I'll check the resistance of the IAC wiring to see 'what's up'; I just hope it's the same as your 93 because I can't find my Volume 2 FSM.
Jake
What scanner did you buy? I'm looking for one with the most bang for the buck. Where and how much? Thanks
Old Sep 3, 2008 | 12:15 PM
  #44
dr_cranii's Avatar
dr_cranii
I have bad idle too on my '95 when it gets warm or after high RPM's. Checked everything!! Never thought about that IAC.
WHERE IS THAT IAC LOCATED???
Old Sep 3, 2008 | 03:01 PM
  #45
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Passenger side on the lower part of Throttle Body. Black plug with 4 wires going into it.
Old Sep 8, 2008 | 06:49 PM
  #46
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I've been searching the threads regarding an idle problem that I'm told is IAC related. However, what I've got happening with my 92 LT1 does not appear in any posts I've looked at. After the engine has reached operating temp and I then re-start it, sometimes (maybe once out of every ten times) the idle will sit at around 1,800 RPM for as long as a couple of minutes. After that it drops back to 700 and everything else is fine. There are no other idle issues. I've done the resistance check and the IAC was in spec.
So, should I trying cleaning it first or just cough up the $80 for a new one and hope it fixes the problem?
Old Sep 9, 2008 | 12:54 AM
  #47
steve40th's Avatar
steve40th
Yes clean it real good with sensor safe cleaners. Also, DO NOT push in the pintle, leave it as is as it can berak easily.
And, go to www.partsamerica.com and look for the part there, and when you find it, printout the price and Checkers/Kragens or Shucks will honor the price. Not 80 bucks I believe its more like 40 something. ZIP code dependent.
Old Sep 9, 2008 | 09:10 AM
  #48
formul89's Avatar
formul89
I removed the IAC on my '94 , cleaned it and the pintle got broken when reinstalling it. Be careful when tightening the bolts because if it goes in slightly on an angle, this will happen. The o-ring was really dry and brittle and tore when I tightened the bolts causing an air leak.
Old Sep 9, 2008 | 09:13 AM
  #49
MK 82's Avatar
MK 82
The installation procedure in your FSM calls for retracting the pintle so it doesn't "get broken."
Old Sep 9, 2008 | 09:32 AM
  #50
formul89's Avatar
formul89
I did that, genius.
Old Sep 9, 2008 | 09:45 AM
  #51
MK 82's Avatar
MK 82
The pointy end goes in first.
Old Sep 9, 2008 | 09:46 AM
  #52
formul89's Avatar
formul89
Old Sep 9, 2008 | 10:56 AM
  #53
lltrevino's Avatar
lltrevino
there is a smart*ss in every forum! they all, at 1 time or another, realize they are not well liked........
Old Sep 9, 2008 | 11:13 AM
  #54
92ragtop's Avatar
92ragtop
Thanks. The price at PA is 79.99.
Would "electronics parts cleaner" qualify as a 'sensor-safe' cleaner? Would you soak the IAC or just spray and brush?
Old Sep 9, 2008 | 11:25 AM
  #55
steve40th's Avatar
steve40th
Yes and/or MAF cleaner. CRC makes them..
Old Sep 10, 2008 | 12:47 PM
  #56
92ragtop's Avatar
92ragtop
On the LT1, is it necessary to remove the TB to get the IAC off? It appears that the bolts holding it on are underneath and it would be very tough to get any kind of wrench in there. I ask because in some other post it was mentioned that removing and reinstalling the IAC was a 20 minute job.
On another note, the FSM makes no mention of a MAF on the 92 LT1. Am I blind or does it actually not exist?
Old Sep 10, 2008 | 01:54 PM
  #57
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yeah, remove the TB. It'll make getting to the IAC motor a lot easier. Yes, your 1992 has one. I clean my TB and IAC pintle yearly. Really mellows the base idle and improves throttle response, too.
To Idle Problems, Maybe your IAC is bad.
Old Sep 10, 2008 | 04:24 PM
  #58
Lichen's Avatar
Lichen
Actually, your '92 does not have a MAF.
Old Sep 10, 2008 | 06:45 PM
  #59
92ragtop's Avatar
92ragtop
Thanks for the advice.
Old Dec 27, 2008 | 11:51 AM
  #60
calvette 11's Avatar
calvette 11
WHat I did was I took the leads from the fluke/multimeter and put them in the iac, where the plug goes in. A/B are the top two(the little tab that guides the plug correctly onto the IAC.) The wires are colored, so A/B will be blue w/white stripe and blue/with black stripe. C/D are light green/white stripe and light green/w black stripe. Look at how the plug goes into the IAC then look at the wires leading into the appropriate port.
Basically they should be in the range of 40-80 OHMS.
I cant find a pic of the IAC itself, but the tab you lift off to unplug it is ontop of AB, and CD are the bottom two you check. Remember, you are checking the resistance between A/B and C/D
I checked and got 49 from a to b
and I got 49 from c to d does this make the IAC good
