Rough Idle Problem,,,,,
Old Oct 29, 2001 | 09:22 PM
Thomas's Avatar
Thomas
Default Rough Idle Problem,,,,,
My '87 seems to be idling very rough from time to time. Almost like it is searching for an idle speed.
Funny thing is, it doesnt do it all the time, and I cant MAKE it do it either. It just seems to happen randomly.
When I am driving it, it seems ok, it only happens when its idling.
Any ideas?
Old Oct 29, 2001 | 09:47 PM
nobodyunknown's Avatar
nobodyunknown
Default Re: Rough Idle Problem,,,,, (Thomas)
First try some fuel injector cleaner & good gas to clean them up.check there connectors.
It could be so many things,dirty air or fuel filter,leaking EGR,PCV valve,fuel pressure,worn timing chain,...
Old Oct 29, 2001 | 10:47 PM
UDLUV12's Avatar
UDLUV12
Thomas,
Same thing happened to my '86 earlier this year. I contacted the forum, and one of the suggestions that I believe helped me the most was the suggestion to be sure to clean my throttle body. After removing the clamps, holding the Mass Air Flow Sensor...I was able to see how much 'carbon' had built up in the throttle body...potentially causing the rough idle I was experiencing. I used some 'STP carb cleaner', a tooth brush, and a clean rag...and went to work. Results: a much smoother idle. Took about 1-1/2 hours. Give it a look.
Good Luck!! John
To Rough Idle Problem,,,,,
