"knocked a hole on the hood with a hammer - then kept enlarging the hole with tin snips and a hacksaw blade - no problem! we now have clearance! "
Obviously not a garage queen
Actually - I am not telling the truth - we punched the first hole in using a pickaxe - just put a piece of wood on the HSR to back it up! - once we got through that we just scored it with a tile knife ands smacked it with a hammer - anywhere that it didn't seperate - we used a drill and just drilled a bunch of holes touching each other. Did you know you could do a seviceable job of smoothing the edges - by just putting a propane torch to the edges? who would of thunk it! worked like a charm - except for the fuel leak!
Why are you running those big fat tyres?They have to slow you down in every respect.I realise you are on a short course but surely skinny would be good ,especially on the front?
Well as far as we can tell - [the Greenwood kit] cost us about
3.5 mph at 145. We ran last month at El Mirage - and went 142.3
(4 runs within .5 mph) . Took off the body kit - left everything else
the same - went back this week and ran 145.7.
It was hotter [this time] - DA about 6000 ft I think, and we didn't
have the tailwind that we had last month - so it may have been an
even bigger difference - but I have no way of quantifying that.
So, apparently a 4 MPH gain from the intake swap.
Too bad it didn't push you past 150. I was hoping you'd see more
payback for your efforts.
so drag force = Frontal area X CD x speed squared / 410
is the formula I used:
150 mph = 355
200 mph = 630
225 mph = 800
These are the drag force - not Hp or anything else!
So how much horsepower is required rear wheel - ?
weight x rolling resistance (0.016 i used) + drag force x speed / 410
150 mph = 165 hp - easily doable for any of our vettes
Originally Posted by Carl Johansson
Looks about right
Originally Posted by SuperL98
Carl, I tried a few years back, to calculate my Cd.
Did a bunch of coast down tests and recorded acceleration data
points... here is one of the old plots.
Red line was theoretical RWHP with .34 CD. Blue line is a Polynomial
trendline from my data points.
I have written on the tires we use before - fat? they are 28 X 4.5 inches on back - 26 X 4.5 inches on front - I wouldn't call a 4.5 inch tire fat by any stretch of the imagination!
Carl "sometimes I tell people 41/2 inches is really 10 inches!" Johansson
Before this thread slips into the archives, would it help anyone for
us to provide a final summary of parts used and steps taken to make
the swap to the Holley Stealth Ram on Carl Johansson's car?
