Crank Position Sensor
Old Jul 10, 2007 | 11:56 AM
lefoy84's Avatar
lefoy84
Default Crank Position Sensor
What does it do on the 96 LT4 and why was it added?
Old Jul 10, 2007 | 12:05 PM
lefoy84's Avatar
lefoy84
Answered my own question.
FSM page 6-256
"The CKP sensor is an electronic device that senses four lugs on the CKP sensor reluctor ring. The sensor provides a signal directly to the PCM in order to process misfiring diagnostics. The CKP sensor has an O-ring seal to protect the sensor from outside oil contamination, and to position the sensor in the center of the engine front cover bore."
Old Jul 10, 2007 | 12:24 PM
toptechx6's Avatar
toptechx6
Exactly, OBDII was a federal mandate on 96 cars and misfire detection is one of the requirements.
To Crank Position Sensor
