Whats required to go Carbed on a 96?
#61
In all honesty the answer has been made very clear...economics. He does not have a "such a good fuel injected engine" he has a long block with serious issues and for someone that does not understand the integrated systems, a running crate motor for $1500 is hard to beat.
It's not like he's arguing against the technology of fuel injection.
It's also pretty clear that he now understands and is moving in the right direction.
I'm not sure how missed all that...you should at least read the thread before jumping down someone's throat with explitives.
#62
Well, at least you've chosen the right profession to pursue.
I retired from the Chicago Police Department as a Lieutenant in 1995 after giving them the best 28 years of my life. LOL
Seems you're zeroing in on one of the blocks recently offered which is fine with me. Whatever works best for you is what you should do.
I'm going to load my stock LT1 in the bed of my nephew's Silverado and take it down to Texas and roll it into my storage locator there.
I can always hang on to it to put in my son's 96 LT1 Vette once he blows his engine with the lead foot that he has.
Good luck in solving your engine problem. Be sure to keep us posted.
Jake
Jake
#63
I went carb on my '86 and I am very happy with it.
My mileage went to hell and I lost the fuel retated goodies on the display, but the horsepower gain more than made up for it.
#64
#67
The reason he doesnt have a good running engine is cause of previous mistakes from what ive read. He had a chance to do it right first go, but it certainly seems as though he failed to take any advice offered to him, which has led to the current situation.
Putting in a crate engine for $1,500 is not the be all and end all of this saga. It sure as hell wont be the fix.
The PCM requires input from the engine sensors in order to be happy. Without that input, many things wont work, including the auto transmission, which requires the PCM to be happy in order to function. So a $1,500 crate engine just got a whole lot more expensive and far more complicated (there goes your economics). Almost everything in the whole car works in and around the CCM and PCM. Without them, might as well gut the car and drive an empty shell, cause almost nothing is going to function properly.
I did read the thread, and a few of the previous threads before i made these comments. If he hadve followed previously given advice, id say he would have an engine that would run fine. And i still want to know why on earth anyone would consider a carby engine simply cause they had water in the oil (which has nothing what so ever to do with the intake or any of the fuel injection system, or engine managment systems).
Because they don't know as much as you. So, the smaller numbers after the currency sign mean less money, cheaper, more economic. Forget what you know,about motors, just look at the numbers..less is less. (I wish I could stop here) So, thinking you can just slap a motor already in built by a pro with no worry about damage to internals and avoid any more self inflicted wounds and move on and get the car running, the lower number, the less work, less chances for mistakes makes sense.AND AGAIN, only knowing ahead of time the difficulties in getting everything to work does it NOT make sense.
All engines come back to air/fuel/compression/spark, no matter how the air and fuel gets in there.
rap87, if you start a "I'm going carb" thread, I will fly Case in from down under, hand him a gun and point him in your direction
#68
I can make this sound simple .When you hook up your trans linkage to a carb engine you will need the linkage set up from holley ,jegs sells it .you will also need a switch to hook to the trans to unlock the converter.If you don't give the electric current to the trans for the converter to unlock it will stay locked up and you will not be able to idle the car and have the converter disengauge.
It will stall every time you come up to a stop light to keep it simple.
#69
Well, RaindDelay said exactly how my feelings and opinions were when I posted these questions and I am glad it came across correctly to someone. Look even, if I ask a stupid *** question, I may not know it cause I don't have the knowledge, but I do appreciate you guys telling me it is, just go soft on the shots to the kidneys hehehe.
Redc4corvette: So, there is a way to make it work, but I assume those items I would need, will end up costing more than fixing what I have now, and which would defeat the fix of saving money and cost me on gas etc.etc.etc. right? Only way I would consider carb is if its brand new and it can be done under 2 grand, otherwise even the worst case scenario with mine I can get it fixed....eventually....that is.
#73
How about a new crate engine? I see that GM has a new 350 horse crate engine called ram jet 350. I saw it on gmperformanceparts.com. It has all of the fuel injection and sensors.. It says installer supplies 12 volt power and fuel and it is ready to go. I don't know anything about it except what it says on the web site, but I stumbled on it.
#74
IT'S NOT AN LT1.
