First Datamaster Scan
Old Jul 10, 2007 | 07:22 PM
jimmers's Avatar
jimmers
Default First Datamaster Scan
I went for a drive tonight and got my first Datamaster readings. I'm slowly learning about all this and have been looking through the readings. I'm wondering if anyone can take a look at it and tell me if there is anything to change because my car is running very rich. Thanks!
http://www.mts.net/~jimmers/Test.uni
Old Jul 10, 2007 | 07:33 PM
jimmers's Avatar
jimmers
My BLM's seem to be at 108 alot which I know isn't good. Any help would be great!
Old Jul 11, 2007 | 09:43 PM
jimmers's Avatar
jimmers
Can anyone give me any tips?
Old Jul 13, 2007 | 02:46 PM
black_89_vette's Avatar
black_89_vette
I'll throw my one cent in here (don't know enough for two cents worth).
108 is really rich. I suggest getting an adjustable fuel pressure regulator and lowering your fuel pressure a bit.
The others who normally respond would probably like to know if it's a modified engine and the size of your injectors and such. If you just bought 24 or 30 pound injectors without altering your chip, this would result in being too rich as well.
Old Jul 14, 2007 | 08:25 AM
rtracy's Avatar
rtracy
Jimmers, I can't look at your file with my version of Datamaster but if you are running rich acrossed the whole log I would put the stock injectors back in it and give it another log. See where that puts you.
Old Jul 14, 2007 | 09:49 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
If you are running stock injectors I would be suspicious of one or more of them are bad. The stock 1990 injectors are notorious for going bad.
Try testing each of them with an ohm meter and see what the resistance across the coils is. Low or no resistance indicates failure of the injector.
Are you throwing any codes?
Old Jul 14, 2007 | 04:55 PM
tequilaboy's Avatar
tequilaboy
If you have an AFPR try reducing the fuel pressure (with vacuum disconnected) by 5-10%. This should bring the blms back up.
Old Jul 16, 2007 | 02:33 AM
Outlander99's Avatar
Outlander99
Jimmers, are you interested in running a scan on my 1990-L98?
Old Jul 16, 2007 | 08:17 AM
jimmers's Avatar
jimmers
I do have a fuel pressure regulator and its set at 40lbs. I guess it would help telling the specs of my engine. I've been posting alot and reading around so I guess I forgot! .
The engine has been rebuilt, Edelbrock intake, Edelbrock runners, 24#injectors, ported heads and plenum, Hooker 2151 Headers, Comp Cam.
Here are the specs of the cam
Duration @ .050"
212* Intake/218* Exhaust
Gross Valve Lift
.488" Intake/.495" Exhaust (with 1.5 ratio rocker arms).
Would it be ok to lower the fuel pressure lower then 40lbs?
Old Jul 16, 2007 | 08:18 AM
jimmers's Avatar
jimmers
My old injectors were leaking quite a bit so I dont have reliable stock injectors.
Old Jul 16, 2007 | 08:19 AM
jimmers's Avatar
jimmers
No codes have been set.
Old Jul 16, 2007 | 08:21 AM
jimmers's Avatar
jimmers
Wow another owner from Winnipeg!! I wouldn't mind doing a scan on your car, PM me.
Old Jul 16, 2007 | 09:12 AM
Outlander99
PM sent I will be out with it tonight provided it does not rain.
Old Jul 23, 2007 | 11:46 PM
fun Pain's Avatar
fun Pain
Do you burn your own chips?
Have you read about VEmaster or VEphd over at thirdgen.org?
if not read it kiks azz, great program for SD ecu's
I would leave the pressure at like 44-47 and tune the computer, while changing FP, might fix some area's of the programing it will hurt others and will limit the amount of power the injectors can support.
( I'm sure you know this but, it is good to have if you don't)
New Flow = Old Flow x √ (new pressure / old pressure)
22.6 = 24 x (sqrt)(40/45) (your old injectors work the same with your modes it is probably lean at wot)
FWHP = ([INJECTOR SIZE (LB/HR) X DUTY CYCLE] / BSFC) X (# OF INJECTORS)
For NA cars use a BSFC of 0.50, for blown cars, use 0.55. Assume a duty cycle of 0.85.
with that all said a good guide line would be.....
24(lb/hr) / .07 (rough) = 342hp (flywheel hp support)
21(lb/hr) / .07 (rough) = 300hp (rough ans. but simple)
19(lb/hr) / .o7 (rough) = 271hp
with your modes/rebuild you should be around the 340ish mark which should need 24lb @ atleast 43 psi.... so my point is let Vemaster fix the cruising fuel and part thottle, and keep all your power too....
Old Jul 24, 2007 | 08:02 AM
jimmers's Avatar
jimmers
I've tried using VEmaster and have had a bit of success. It will correct most of the rich cells, but after using it a few times I have alot of lean cells now. What exactly is VEphd, I've never heard of it? Does it do the same type of thing as VEmaster?
Old Jul 24, 2007 | 08:34 AM
adi4's Avatar
adi4
Old Jul 25, 2007 | 10:15 PM
fun Pain's Avatar
fun Pain
yes it is along the same lines, I think it was just a rivision or a modified version. I am not sure which came first.
To First Datamaster Scan
