Can the guide plates be removed?
Old Jul 10, 2007 | 07:35 PM
STEVEN13's Avatar
STEVEN13
Default Can the guide plates be removed?
Hi,
Car:1992 LT1
I recently installed new lifters, LT4 springs, and 1.6 self align/rockers.
Engine runs fine, smooth, etc...However the right side seems to tap ( always has).
I am thinking that maybe it's the push rods against the guide plates. If I shim the studs to compensate the difference would there be any other possible issues?
Thanks!
Steve
Old Jul 10, 2007 | 07:53 PM
aboatguy's Avatar
aboatguy
Since your using self aligning rockers you can remove the guideplates. You may have long enough studs to remove the guideplates without using spacer. (rockers are held down on the stud by polylocks so if stud is long enough removal of guideplate is a non-issue) However, I don't believe guideplates are going to cause a tapping noise.
On a different note 95 did not have guideplates when it was stock; however, a buddy's 92 did.
Mike
Old Jul 10, 2007 | 09:39 PM
VenkmanP's Avatar
VenkmanP
No LT1s came with guideplates. They are assembly plates. Take them off if you like.
Old Jul 10, 2007 | 10:40 PM
STEVEN13's Avatar
STEVEN13
Thanks guys for the quick response!
Being as the 1.6 ratio is shorter than the 1.5, would'nt the push rod be closer (to the rear side of the guide plate-header side) and maybe touch slightly?
I will remove them and post if it made any difference.
Thanks again,
Steve
Old Jul 11, 2007 | 02:57 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
It's not a solid lifter cam so you should have no problems.You also have self aligning rockers,nothing need to hold them in place.
Old Jul 11, 2007 | 04:55 AM
engle1147's Avatar
engle1147
Originally Posted by STEVEN13
Hi,
Car:1992 LT1
Thanks!
Steve
You should have changed the push rods too. Old parts -- even though they look good -- they can cause these types of problems.
Are the rocker studs all tight? (Use a crow's foot to check'em)
Could be a loud fuel injector!?
Try a thinner motor oil or switch to synthetic...the old/new lifters may not like the oil your using (hydrolic roller lifters use an internal cushion of oil to raise the rod seat. Could be debree inside that "right" side of the block partially blocking (starving) the oil passages for the lifters.
Leave the plates alone these are not the noise!
Old Jul 12, 2007 | 10:11 PM
STEVEN13's Avatar
STEVEN13
Thank you!
Old Jul 12, 2007 | 10:17 PM
STEVEN13's Avatar
STEVEN13
Rocker studs are tight. Yes the fuel injectors make noise-but this is valve train related.
I have tried 5w 30 and 5w 50 (5w 50 is what I run at the track)
Oil is getting to all rockers as I ran it with the covers off and can see.
The push rods appear to be ok-but I will re-check them.
I will post my results.
Thanks for your help!
Steve
Old Jul 13, 2007 | 07:59 PM
STEVEN13's Avatar
STEVEN13
Default Update
Guides removed and and new pushrods installed........SAME NOISE!
Car runs fine so I will live with it.
Thanks for the help!
Steve
Old Jul 13, 2007 | 09:12 PM
Strick's Avatar
Strick
My 92 sounds like a singer sewing machine, but runs well. I think the mag valve covers transmit the sounds of the valve train very well.
Old Jul 13, 2007 | 10:19 PM
STEVEN13's Avatar
STEVEN13
Well I'm glad my engine is not the only one!
May try the composite valve covers.
Steve
Old Jul 13, 2007 | 10:40 PM
anesthes's Avatar
anesthes
Steve
What procedure are you using to adjust the valves?
-- Joe
Old Jul 13, 2007 | 10:54 PM
black96lt4c4's Avatar
black96lt4c4
why would it only tap on the right side?if it is a valvetrain noise,can you isolate the particular cylinder noise and if its intake or exhaust?or both?ive seen camshaft lobe ramps cause this issue before.the rocker oiling check was a good idea.have you tried to adjust the noisy rocker or rockers with engine running?i would check the rocker position where it contacts the tip of the valve.a mushroomed valve tip or valve guide problem could cause incorrect alignment.you mentioned it didnt have solid lifters, so in theory oil pressure should take care of adjustment after preload.good luck.junior
Old Jul 14, 2007 | 08:52 AM
anesthes's Avatar
anesthes
Thats sorta what I was getting at. If he used the procedure in the manual to tighten the valves, he might end up with a few too tight, and a few too loose.
-- Joe
Old Jul 14, 2007 | 09:41 AM
scranage's Avatar
scranage
The plates that came on my 92 had the exact same markings as the new GM guide plates I bought to replace them when I did my heads. Drawing a file against them they seemed to be hardened too (maybe just case hardened, but not just untreated mild steel).
Old Jul 14, 2007 | 09:51 AM
anesthes's Avatar
anesthes
If the rockers are self aligning, they don't need guide plates. Look at the rockers. If they have guides on the edges to keep them on the valve, they are self aligning. If not they need guide plates.
Corvette forum rule #1: Don't trust anything you read, check it, measure it, verify it yourself.
-- Joe
Old Jul 14, 2007 | 09:55 AM
scranage's Avatar
scranage
My point isn't that they were needed to guide, it is that they were the same part # as guide plates.
To Can the guide plates be removed?
Old Jul 14, 2007 | 09:58 AM
Jansenwins's Avatar
Jansenwins
I certainly don't want to give misleading advice here but I have heard that you do NOT want to run with self-aligning rocker arms and guideplates at the same time....from what I understand, they can tend to "fight" each other, causing unwanted friction/binding.
Anyone else know anything about this?
Old Jul 14, 2007 | 10:06 AM
scranage's Avatar
scranage
Like I said, my car came from the factory with the self aligning rockers, and "assembly plates" that were dimensionally identical and stamped with the same part numbers as GM guide plates.
Old Jul 14, 2007 | 10:09 AM
aboatguy's Avatar
aboatguy
Steve,
I was going to mention your car but didn't.
However, I was there and Steve's car had (plates) with the same markings as the GMPP GUIDEPLATES and his car seemed to be an unmolested stocker.
