a/c help
Old Jul 11, 2007 | 01:10 PM
mikeremax's Avatar
mikeremax
Default a/c help
I have a 93 with auto a/c. when I turn the a/c on it will blow hot but the a/c clutch does not engage and cooling fan does not turn on. The fuse are fine. I drove the car 2 days before ande everythink was fine.
Old Jul 11, 2007 | 01:52 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Are you low on refrigerant? The compressor is designed to "lock" as a self-destruct failsafe if it doesn't have enough refrigerant to operate properly.
Old Jul 11, 2007 | 03:06 PM
mikeremax's Avatar
mikeremax
I think I may be low on refrigerant but does stop the cooling fan from going on?
Old Jul 11, 2007 | 03:21 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I believe it would, because the compressor isn't running.
Old Jul 11, 2007 | 03:30 PM
mikeremax's Avatar
mikeremax
Old Jul 11, 2007 | 03:37 PM
mikeremax's Avatar
mikeremax
Which line do you use to charge the a/c? I have charge other cars but I can not find the line to charge with.
Old Jul 11, 2007 | 08:24 PM
89 Bob L's Avatar
89 Bob L
It definitely sounds like you are low on freon. The fan will not go on unless the compressor/clutch engage. you add freon to the low pressure side. The valve attachment is on the accumulator, not far from the compressor. It should be silver in color and be about the size of a 16 oz soda bottle. Turn the engine on and let it idle, turn on the a/c to maximum cooling. Attach-add the freon with the can up side down. Should take about ten minutes too empty. As the can is emptying turn the can from the twelve o'clock to three o'clock to twelve o'clock position every 15 seconds or so. As the freon is entering the system the clutch should engage and the fan will go on. Do not use more than two cans of freon. Hope this helps.
Old Jul 11, 2007 | 09:03 PM
mikeremax's Avatar
mikeremax
Yes this help a lot. Just low on freon thanks
Old Jul 11, 2007 | 10:05 PM
Lichen's Avatar
Lichen
With a '93, you are still running R-12 and will not be able to recharge it yourself. Maybe Freeze-12 is available?
Old Jul 12, 2007 | 11:32 AM
mikeremax's Avatar
mikeremax
Mine has been chenge over to R134
To a/c help
