DYI alignment
Old Jul 16, 2007 | 09:58 AM
STEVEN13's Avatar
STEVEN13
Originally Posted by quickcat
I figure I could ask again. Maybe I should start a new thread with this question about the poly bushings.
What are the typical alignment specs for the C4s? I guess they would be in my FSM if I look, but more importantly, do the specs need to be changed when poly bushings are installed. I have known people to have issues with this on other cars.
Yes the factory specs are in the FSM (+/- .5 degrees is within spec)
If the car is not raced the stock settings are fine. If you do race (road race or auto-x) then its your choice of how you prefer the car to handle.
Always a good rule to at least re-check your alignment settings after doing any major suspension work. If for example you had an alignment done with worn out bushings and then installed new bushings the alignment would have to be reset.
Steve
