Will This Stuff Work In My Differential???
Old Jul 12, 2007 | 08:11 PM
Steel Breeze's Avatar
Steel Breeze
Default Will This Stuff Work In My Differential???
Ok, my pictures didn't turn out to good. Just got this camera, and haven't figured out how to work it yet.
The Posi additive say's in fine print: prevents chattering, jerking & slipping. meets oem recommendation for limitied slip diffs. GM# 1052358, FORD# M2C118-A, CHRYSLER# 4318060, and most imports. 7oz. in container
The Gear Lube is full synthetic... Thanks...
Shot with 7M CCD CAMERA
Old Jul 12, 2007 | 08:20 PM
Aardwolf's Avatar
Aardwolf
It looks right, do check the gear lube label to see if it already has the LSD additive in it though. You don't need to add extra if so as to much is not needed.
Old Jul 12, 2007 | 08:39 PM
Vito.A's Avatar
Vito.A
It probably will work fine.
I put a new ring carrrier in my car a couple of months ago and I used Mobil 1 synthetic gear lube and added the GM positraction additive. It has been great with no chatter in and out of tight parking spots.
Old Jul 12, 2007 | 10:33 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Per gordon (2) posi per change....
Old Jul 12, 2007 | 11:38 PM
Steel Breeze
I figured the gear oil would be fine, but was worried about the additive, as it is not the GM stuff. The container holds 7oz. Perhaps I should abondon that, and go with the GM stuff. Actually the rear end is out of the car. While I had the car apart as far as it was, I figured I would drop the carrier, drain the old oil, have it checked by my rear end guy, and put in new lube. I also glass beaded the bat wing. Well actually I put in 6 new U-joints, and did the whole 9 on it. Just not sure about that Posi Additive. Got it at NAPA, and they claimed it would work fine, no problems. Probably be better to be safe than sorry. Might have to go see the stealership...
Old Jul 13, 2007 | 12:32 AM
etown brawler's Avatar
etown brawler
the gear oil is good but i would stick with the gm posi additive ,2 bottles of it and your mint.
Old Jul 13, 2007 | 07:35 AM
runner140*'s Avatar
runner140*
Tom, thats the exact combination I used. Works great.
To Will This Stuff Work In My Differential???
