Injector install
Old Jul 12, 2007 | 11:35 PM
Livin the Dream's Avatar
Livin the Dream
Default Injector install
What do you guys use to lube the o-rings on the injectors before install? just oil?
Also is it normal for the lower half the injector ( below o-ring in intake) to appear carboned and wet?
Should I try to clean the injector holes in my intake or use some seafoam afterwards?
Oh and I used the directions on the removal- top notch
Although I used a rachet wrench with my 1/4 torx
Old Jul 12, 2007 | 11:47 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I just use oil, but grease would work. That's normal wear for the injectors, and it try to clean it out before putting the injectors in, but any soil will just be sucked into the cylinder when you start it, and it shouldn't cause any problem.
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I just used some oil, as for the injectors being carboned, the ones on my car were clean, I would think about getting them serviced by Rich at Cruzin Performance.
Gook luck
Old Jul 13, 2007 | 11:23 AM
rickneworleansla's Avatar
rickneworleansla
I used Marvel Mystery Oil. It was recomended by another forum member. It's cheap and easy to find.
Old Jul 13, 2007 | 12:41 PM
bd2626's Avatar
bd2626
That's what I used Used a Q-tip soaked in it to clean the injector holes also.
Enjoy the ride!
Old Jul 13, 2007 | 01:23 PM
89 Bob L's Avatar
89 Bob L
The above two posts were right on the mark. Use q-tips to clean the area and use some marvel mystery oil. It will help the injectors go in and seat easier, giving you a better fit.
Old Jul 13, 2007 | 09:59 PM
Livin the Dream
Thanks The q tiups and marvel oil did the trick! Fired the pump up and had about a 10 psi drop in about 63 minutes! Can't wait to fire it up
Old Jul 13, 2007 | 10:20 PM
jimmyu2's Avatar
jimmyu2
I used vaseline...put it on the injector o ring and on the fuel rail hole. it stays on the o ring, and worked well great.
Old Jul 14, 2007 | 08:52 AM
Sam Lam's Avatar
Sam Lam
I think any type of petroleum lubricant would work to lubricant the tight fit of the "O" ring to the mating holes. If you do not lubrinant the O rings, the surface of the ring may be damaged and you will not have a proper seal. However, I would not use a lubricant with silicone content due to potential oxygen sensor problems.
Old Jul 14, 2007 | 03:15 PM
skybolt31's Avatar
skybolt31
I haven't done my injectors yet, but whenever I put an o-ring in anything, I use some stuff called Parker O-Lube:
http://www.parker.com/o-ring/Products/Lubes.htm
It is available here:
http://www.aircraftspruce.com/catalo...arkerolube.php
It is absolutely not necessary, any of the previous suggestions will work fine. I bought a tube of the stuff for around $10 and I have a life time supply for me and all my friends..............
Old Jul 14, 2007 | 03:44 PM
MikeC4's Avatar
MikeC4
that's what I use...more viscous and stays on, injectors slipped right in.....
Old Jul 14, 2007 | 04:07 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
KY should work even better!
To Injector install
