I'm not sure if this is helpful, but I recharged my '85 which was still an R12 setup using RedTek. Can't get R12 in Canada legally and for environmental reasons, why would I?? The RedTek came as a DIY kit and the first can is a sealer/conditioner. I had no history or any idea how long the air had not worked; all I knew was the compressor was not seized. Put one can of sealer/conditioner in, and one can of R12a refrigerant and lo and behold, the compressor kicked in and it is now blowing ice cold and has been doing so now for a month and a half.
This sounds really good- I may need to try this. How did you know your compressor isn't seized? Mine won't kick on today with the dashboard switch.
As a preliminary test, with the engine NOT RUNNING, grab hold of the compressor pulley (sort of a flat face) ahead of the clutch and try to turn it. With a good grip, you should be able to turn it.
No disrespect. It's your car but here are a couple of reasons why you should have just fixed the leak and converted to R134A.
R12a is a blend. Not good because the chemicals can seperate.
R12a is flammable.
The manufacturer of R12a claims lower compressor head pressure than
r12 and r134a but shows no evidence.
Manufacturer says to use R134a high and low adapter fittings for the conversion.
Each manufacturer is supposed to provide proper adapter fittings that identify the refrigerant type.
If R12a uses R134a fittings it probably is a blend of R134a and who knows what other chemicals.
Most shops probably won't touch the system if it ever needs service because it will contaminate their equipment.
You are probably low on refigerant. Jump the pressure cycling switch while the car is running, the clutch should engage. If it doesn't, get a test light and check for power at the compressor while the pressure switch is jumped. If you have power and the clutch isn't engaged then your compressor/clutch is seized.
Great- thanks! I was told about a year ago from a shop that wanted ~$1k to replace the A/C. If this can be as easy as a recharge, I owe you a cold one!
Has anyone ever had success replacing the seals in the A/C compressor?
I’m am taking a shot with my ’89 ?
So any advice is better than done
Are you talking about the seals that are between the manifold lines and the compressor or the internal seals of the compressor? If you are talking about the ones at the lines, then it's worth a try, we do it all the time. If it's the internal ones in the compressor, I wouldn't bother wasting your time.
Either way, just make sure your system is evacuated before you attempt to open the system.
$1k - $1200 is an average price for an a/c system overhaul; if you replace the compressor, you need to replace the receiver drier and orifice tube and technically the condenser
Try evacuating your system and recharging it, you might just have a leaky seal that will oil up and at least get you through summer.
R12a is flammable.
No disrespect felt - you're right, to each his own. Before converting to R12A, I consulted with a licensed technician who has been using it for several years, without a problem and with the real cost of a complete conversion to R134, this was clearly a simpler and cost-efficient solution. Figured - if I really need to ante up for a complete conversion, why not try this first. I've also heard the opinions of others about the different molecular properties, etc. etc, but so far, I haven't seen or heard any evidence that backs it up. I'm not too concerned when we stop and consider all the chemicals that we mix together as manufacturer's products and consumer preferences change (e.g. lubricants, coolant, fluids, fuels....) I'll leave those discussions for anyone who wants to take it up with RedTek or any other manufacturer of the 'new and improved' version of whatever.
Thanks again- I'm clueless on A/C so one more question if I may. I'm an 86L configured for R12. I know I'm not capable, so if I take it to a qualified repair shop, will I need to change over to R134 or will they be able to try with R12? Any idea of what that would cost? (Ooops- that looks like two questions!). I also hope I'm not thread stealing- I hope I'm keeping this related.
I don't know if R12 is still available in your area; it's getting pretty scarce around here in California. I do know that it is a lot more expensive for R12 then R134. Anyway, to convert over to R134 you need to, at the least, replace your receiver dryer, then you need to have the system completely evacuated and flushed by a qualified shop. All traces of the R12 must be removed because R12 and R134 are NOT compatible. The shop needs to use an Esther oil and NOT any type of PAG oil because Esther and PAG are NOT compatible and some traces of the old stuff is gonna get stranded in the condenser and evaporator.
So bottom line is, if you can get R12, just have them shoot it for you; that would be your simplest (and cheapest) route even though the R12 is more costly, the cost to convert would supercede it the price difference of the two refrigerants.
Also, ask them to add a dye to the system so that finding a leak later will be much easier.
Hi, the A/C kit turned out to be only a front seal repair, which is all i would need. I received it from Lawerenceville Auto Parts, Lawerenceville Ga. , but most any good store [usually not a chain] should be able to get it.
Trouble is getting the install tool. I still have not gotten it, and perhaps this is good.
However, it seems the R134 swap will work, but your A/C will perform at a reduced level, especially in the hot Georgia summer. You need the R12 [or 12A] to get the bang for the buck.
Also, the other is a specific R134 Clutch that is needed [oversized? likley] They make a specific new R134 compressor as well [ no core charge so I keep the original , and that is never a bad thing].
$650 for both parts, $65 for an accumulator, and a new 134 systems is the result. That is the way I ended up going.
I get free A/C service from a Pro, so the 134 is free, so is the Nitrogen flush, and the vacuum pumping. So it shakes out as a reasonable alternative and I can play around later if I want.
To remove the clutch, hold the hub with a strap wrench or oil filter pliers and unbolt the nut. If on the car, put your hand underneath it to catch any shims and pry off the face plate. Pulley and coil are held on with snap rings. Everything else is outlined by the guy doing the Nippo on his Porsche. It's a different model but the seal installation is the same.
Really no difference between the R12 and R134 compressors, though the later years seal up the main hose with sealing washers instead of o-rings. If you buy a replacement, make sure the manifold matches what yours is using.
Thanks for the details
The Compressor shown in the Pelican procedure differes from the ’89 I have.
The ’88 Nip. Comp. seal goes in from the backside and the Carbon seal and retainer are one part, in the kit I received. They resemble the Pelican detail, but are different.
The “tool” looks like and alignment device possibly used when setting the Seal/Retainer?
The Compressor they sold me is for the ’92 – ’96, and have a different Hi/Low hose configuration, so this little adventure continues.
Do I swap the compressor “tops” so the 88 hoses fit, or spring $63 for ’92 hoses?
To further confuse the issue, I am told I have to change to a 134 Clutch? Why?? Who knows, but the challenge is to find out.
