Need Help With Com Port For Tunerpro
Old Jul 13, 2007 | 11:41 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Need Help With Com Port For Tunerpro
I'm not so savy with computers
I'm trying to get tunerpro to recognise my cable through the com port.
What do I have to do ?? No info in their help pages. I have tried changing com port 1-4, no luck. Do I have to configure the port somehow ?? I'm using a serial connector, 2 trans cable.
Datamaster has no problems
Old Jul 14, 2007 | 04:08 PM
ebisko's Avatar
ebisko
Default re: Com Port
Hi, I can't really help you with tunerpro, but cats tuner and pretty well most programs have a section to change the com port settings. In CATS tuner in the options area you can change the port setting and even hi-lite what is available. I'm sure you will find something. Good-luck, Earl.
Old Jul 14, 2007 | 07:16 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
I'm zero help too, but have you tried contacting Mark Mansur over at Third Gen.org (screen name is Mangus) - he would surely be able to help you.
Old Jul 14, 2007 | 07:59 PM
AGENT 86's Avatar
AGENT 86
Maybe my Datamaster is hogging the com port Since Datamaster works, I will play with Tunerpro at a later date.
Old Jul 15, 2007 | 04:10 PM
JackDidley's Avatar
JackDidley
86, Mseven just told me this the other day. Right click the gray background on the screen, when preferences pops up click it and you can set the Comport.
Old Jul 15, 2007 | 05:50 PM
AGENT 86's Avatar
AGENT 86
Iv'e done that, tried 1-4 comports, No go. Datamaster runs and uses com port 2. I'm not computer savy enough to figure out if Datamaster is hogging the port.
Old Jul 16, 2007 | 01:12 AM
RRT vette's Avatar
RRT vette
I use a Moates ALDL cable/converter. When I plugged the cable up to the USB port, it said "new software detected" and asked if I wanted to install. I completed the install process with a CD rom he gave me. You may need to install a driver.
http://www.moates.net/product_info.p...products_id=66
Old Jul 16, 2007 | 08:05 AM
AGENT 86's Avatar
AGENT 86
Thanks, but I'm using a serial connector.
Old Jul 16, 2007 | 09:35 PM
Zabman's Avatar
Zabman
Hi Guys...TunerPro is only configured to use USB Ports. You must use a USB to ALDL cable/adapter and depending upon which one, a special USB Driver may be needed. If you use the Moates.net cable, then use his supplied driver, as someone previously stated... Good Luck, Mark
Old Jul 16, 2007 | 09:57 PM
-js-'s Avatar
-js-
In version 4.13 of TunerPro RT its under Tools>Preferences>ALDL/Emulation
Plenty of options and a test for valid cable settings.
Old Jul 17, 2007 | 08:21 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Dan - once you get the proper USB cable and install the associated driver, you will have to assure that any conflicting software such as a Palm Pilot, Blackberry or other application using the com port is not active. Just shut them down before you boot up your tuner software.
Old Jul 17, 2007 | 08:24 AM
AGENT 86's Avatar
AGENT 86
Thanks guys, I didn't read anywhere that a serial port is no good.
For now, I'll continue with Datamaster. Can I build the adapter for cheaper than I built the cable.
Old Jul 17, 2007 | 09:49 AM
tequilaboy's Avatar
tequilaboy
I use a serial cable with no problems with TunerProRT Version 4.13. I have a cable from AKM cables.
Which version of TunerPro or RT are you using?
Old Jul 17, 2007 | 03:14 PM
AGENT 86's Avatar
AGENT 86
RT
I'm using my home built 2 trans cable. Works well with Datamaster and Moates.
Old Jul 17, 2007 | 04:38 PM
tequilaboy's Avatar
tequilaboy
Dan,
Are you getting 8192 baud data or only 160 baud with datamaster? Or how fast is the sample rate (roughly 1 second or 100 ms)?
Maybe send me one of your datamaster uni files, I'd like to check it out.
Its been awile since I used my old homebuilt transistor cable, but I don't think it could handle 8192 baud.
Old Jul 17, 2007 | 09:01 PM
AGENT 86's Avatar
AGENT 86
Dan,
I'm believe i'm getting 8192, but iv'e been wrong before.
When I get a chance, I will pull a file off my laptop.
Old Jul 18, 2007 | 09:13 PM
Mangus's Avatar
Mangus
Wow, lots of bad information in here, guys. I've gathered (in my lurking) that y'all are diehard Datamaster and TC guys. I love how this evolved into a Datamaster thread. That's alright, though. I suppose that means I need to try harder to convert you. Let me know what it would take!
Anyway, to answer the original poster's question(s) and clear some things up:
- TunerPro is designed to work with serial (COM) ports (not just USB)
- TunerPro does not auto-detect ALDL cables. It only detects emulation hardware
- To use ALDL cables, in preferences, set the ALDL interface type to MAX232, then set the COM port to the appropriate COM port for your cable (for true serial it's usually COM1 or COM2, for USB it's often COM3 or higher)
- If you have another application open that is using the COM port, you'll need to close it before any other software can open the COM port. This means you need to close Datamaster first.
Old Jul 19, 2007 | 10:14 AM
AGENT 86's Avatar
AGENT 86
Thanks Mangus
Old Jul 20, 2007 | 09:49 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Mark,
Good to see you on here. Sorry we missed you at Grumpy's Memorial.
To Need Help With Com Port For Tunerpro
