I have a '92 & i want to put an in a LT4 motor; it comes with the computer and wiring harnesses...
1) Do i need the OBII computer or can i tweak my OB1?
2) If i do need that computer... will i also need another set of O2 sensors for the computer to work properly? i thought LT4's and even '94- LT1's have 4 sensors while i only have two...and if so how is it an ordeal/ possible to wire something like that to the new computer???
You need to swap out the LT4 knock sensors with your original sensors. Otherwise you old ECM will not like the shunt resistors of the newer engine and will set a code and it will run like do do.
