Trouble With 94 Distributor
Old Jul 14, 2007 | 04:07 PM
THOMASG05's Avatar
THOMASG05
4th Gear
Default Trouble With 94 Distributor
Hey Can Anyone Give Me Advice .....i Have A 94 Corvette And My Optispark Distributar Went Out , Ive Heard You Can Change It From An Optispark To A Coil Pack Any One Know Anything About That
Old Jul 14, 2007 | 04:41 PM
FD2BLK's Avatar
FD2BLK
Not exactly you cant remove the Opti. You have several choices depending on what is wrong with your distributor. If it is just the cap carbon arched and the low voltage side is still functional you can get either the Delteq system that uses the northstar coil pack or the LTCC that uses LS1 coil packs. If the low voltage side is shot you need a new Opti and once again you have choices, Original GM, MSD or dynaspark
http://www.delteq.com/
http://www.bailey-eng.com/LTCC.html
http://www.msdignition.com/2006/06-4.htm
http://www.dynaspark.net/
Old Jul 17, 2007 | 11:32 AM
Rich's94vert's Avatar
Rich's94vert
Default Opti choices
My Opti just died again about 50,000 this time. I'm sticking with GM found a new one at Full Throttle Corvette [sam@fullthrottlecorvette.com] for $360. I dont see or feel any coolant it just seemed to have died. Has any one installed the ventilation kit I see advertised and if so has it proved worthwhile?
To Trouble With 94 Distributor
