ZF6 6th Loading...
Old Jul 17, 2007 | 11:24 AM
nogoodsam's Avatar
nogoodsam
Default ZF6 6th Loading...
Ok, in other post I've read comments about 6th gear not being able to tolerate high loads (says at 150mph shifting into 6th). So don't use 6th gear to accelerate hard. I didn't want to steal the thread, so I didn't ask.
Something about the 6th gear syncro is shared with reverse so the high loading will "burn it up" due to heat.
Is this true? What's the deal?
Old Jul 17, 2007 | 11:34 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Okay.
I won't.
Sam, you ever actually tried to accelerate hard in sixth gear??
I believe that is another old wives' tale.
Like the one that says you have to open the hood and the doors in order to raise the C4 on a lift.
Once you are in sixth, the syncro is on lunch break. Even so, I usually have to downshift into fifth in order to accelerate, so I don't think this is an issue for most ZF6 owners.
If you tried to actually accelerate in sixth gear, it would take so long that the engine oil temp would rise to dangerous levels before the gearbox would be threatened.
Larry
code5coupe
__________
not easily impressed....
Old Jul 17, 2007 | 01:48 PM
nogoodsam's Avatar
nogoodsam
I was just relaying what I've read here and wanted some discussion.
I tend to agree that it seems like a myth.
I haven't tried accell hard in 6th gear, but I haven't been to 160mph yet to shift into 6th gear either. :-)
Old Jul 17, 2007 | 02:05 PM
bogus's Avatar
bogus
top speed is found in 5th. not 6th. there isn't enough torque to overcome the ratio.
as for "sharing" synchro's, that sounds like a pile of crap. It makes no sense at all.
Old Jul 17, 2007 | 02:18 PM
nogoodsam's Avatar
nogoodsam
Agreed for stock, I figured I'd might use 6th gear with 4.10 gears?
Old Jul 17, 2007 | 02:23 PM
nogoodsam's Avatar
nogoodsam
Here's another thread I just found discussing this stuff.
http://forums.corvetteforum.com/show...syncro+reverse
To ZF6 6th Loading...
