Distributor Cap - Cause or Symptom - Misfire ?
Old Jul 18, 2007 | 03:14 PM
tmetti's Avatar
tmetti
Default Distributor Cap - Cause or Symptom - Misfire ?
I have had my 85 for about 2 months now and have made some major improvements. I always noticed a slight hesitation, that I thought was a misfire. The car ran OK, and I thought it was normal for its age.
It pointed to the electrical system and I bought a new ignition coil. When I was in there, I noticed my distributor cap, one of the terminals was corroded. I changed this with the ignition coil, and my car runs MUCH better. In fact I am getting 26.5 MPG on the freeway, almost 3.5 MPG better than I have ever had with it before.
My question is , was this the cause of my problems, or a symptom, and how can I confirm that?
Thanks for everyone who posts useful info on this site, its a lifesaver!
Old Jul 18, 2007 | 03:21 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
correct, if one of your cyl's wasn't firing, then you would have performance and millage issues...
Old Jul 18, 2007 | 04:35 PM
Keystring's Avatar
Keystring
Even though you are getting better gas mileage,I would consider changing the plug wires as well.
If you have that much corrosion on the cap, I'm sure the wire connection is just as corroded.
It might be just a short time before you have the same problem again if you don't change them.
At least the one wire anyway.
Old Jul 18, 2007 | 04:38 PM
86PACER's Avatar
86PACER
Perhaps. Put it back together the way it was. Then if you have a timing light, connect it to that wire and just point the timing gun to your palm and note the flashes. You'll be able to "see" what's going on. If it does not look the same as the rest of the wires, buy a new cap. Change the rotor while you're in there. Remember, for the coil, the plunger goes in the hole first, then the round rubber peice on top of that.
Old Jul 18, 2007 | 04:40 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
He changed the cap.
Old Jul 18, 2007 | 04:42 PM
86PACER's Avatar
86PACER
You're right. I read too fast. Then it should be obvious. If the car improved and smoothed out after he changed that, then yes that must have been what was wrong. Ignition coils usually just either work or die all together, so it's more likely the cap was what fixed it.
If he wants to "confirm" then just put the old coil back in and start it. If no change, then it was the old cap that must have been bad.
Old Jul 18, 2007 | 05:05 PM
tmetti's Avatar
tmetti
My question was more on the lines of...will the corrosion come back? Could there be an underlying electrical problem causing that much corrosion, or perhaps just a loose wire?
I forgot to mention that some of the paperwork I have on the car says that the cap was changed about a year ago...Is this going to keep happening?
Old Jul 18, 2007 | 05:13 PM
86PACER's Avatar
86PACER
What does the bottom inside of that wire look like? You never said if you changed the wires or not. If it looks fine, just forget about it.
Old Jul 18, 2007 | 05:19 PM
tmetti's Avatar
tmetti
Didn't change the wires, and they looked good.
Old Jul 18, 2007 | 06:03 PM
86PACER's Avatar
86PACER
Then I would not worry about anything with your new cap.
Old Jul 18, 2007 | 06:24 PM
BADDUCK's Avatar
BADDUCK
I don't understand the need to confirm. If it's fixed that was it. It's a $25 part, drive it.
Old Jul 18, 2007 | 06:44 PM
_twisted_'s Avatar
_twisted_
Corrosion may come back - you could dab some dielectric grease inside all the plug wire boots - it will also help when you remove the wires later
Old Jul 18, 2007 | 06:52 PM
86PACER's Avatar
86PACER
Good point.
To Distributor Cap - Cause or Symptom - Misfire ?
