Sensitive Throttle?
Old Jul 19, 2007 | 02:15 AM
RetroTA's Avatar
RetroTA
Default Sensitive Throttle?
When accelerating from a stop my throttle response seems to be very sensitive to the point where the car lunges with little effort on the pedal. I find myself flexing my foot to apply minimal force to the pedal. I believe
the TPS is original and the scanner indicates normal voltage throughout the travel of the pedal? Can anyone relate? Or any suggestions? I noticed the TPS seems to be adjustable but I dont want to start messing with it
and throwing off the computor. It has been like this since I bought it a couple years ago.
Old Jul 19, 2007 | 03:30 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Is the throttle body sticking off idle, making it difficult to feather into it?
Old Jul 19, 2007 | 10:36 AM
staugur's Avatar
staugur
Mine was like that when i got it.it turned out to be the springs on the TB.Someone had messed with them and not put enough tension on them when rebuilding it.
Old Jul 19, 2007 | 12:03 PM
all show and more go's Avatar
could it be u drove a 4banger before and the v8 has too much throttle responce for u to handle,lol.
Old Jul 19, 2007 | 12:25 PM
CentralCoaster
Old Jul 19, 2007 | 12:31 PM
RetroTA's Avatar
RetroTA
The shaft seems to be moving freely with no binding, I will take a look at the spring tension. Its not a huge problem but it is an annoyance.
Old Jul 19, 2007 | 12:38 PM
RetroTA's Avatar
RetroTA
Old Jul 19, 2007 | 02:26 PM
Biker's Avatar
Biker
My '86 has the exact same problem. Lubricating the throttle body and cable didn't help. I'll have to check the spring tension.
Old Jul 19, 2007 | 02:30 PM
94z07fx3's Avatar
94z07fx3
Do you know if a PO installed one of those worthless throttle mods?
There is, in the aftermarket, a device that will make the car do exactly what you are describing.
Old Jul 19, 2007 | 06:27 PM
staugur's Avatar
staugur
Mines a 383 lingenfelter and someone had been playing with it.When I got it you had to push the throttle so hard your leg ached.There was this big coil spring attached to the throttle to pull it closed.Well after I took it off and used the car boy oh boy.Hit the throttle ,butterflies flopped virtually full open,smoke pouring off the tyres and i needed to change my shorts.When your not expecting it it comes as a shock.Anyway you will see there are two springs on the operating arm.You can assemble it without winding some tension onto them which is what some idiot did with mine.Can't remember but I think it was two turns.Perhaps someone else knows.
Old Jul 20, 2007 | 12:22 PM
RetroTA's Avatar
RetroTA
Im thinking spring tension too, The pedal is fairly hard to push compared to most. I'll check into spring tension? Bought car from original owner no mods that I know of other than a few I did .
Old Jul 20, 2007 | 12:27 PM
RetroTA's Avatar
RetroTA
What is a PO anyway. Im guessing some form of idiot?
Old Jul 20, 2007 | 12:31 PM
kalister1's Avatar
kalister1
PO = Previous Owner
Old Jul 20, 2007 | 12:32 PM
89onlyZ51's Avatar
89onlyZ51
Is it a stock or enlarged throttle body? The bigger ones make the car FEEL like it's faster because you're letting in a lot more air at throttle tip-in.
Old Jul 20, 2007 | 12:56 PM
Demonic85's Avatar
Demonic85
I felt the same way when I first drove mine. It was cause I was used to driving around in an old V6 Buick that had like 150 HP
Old Jul 20, 2007 | 09:18 PM
DM VETT's Avatar
DM VETT
Had same problem with my 90. I thought it was just the way the throttle was. Stayed this way for 6 monthes as I don't drive it much. A couple of weeks ago while driving to show the car started surging at highway speed and service engine light came on. Throttle problem got worse as well. I finally pulled codes and found it was oxygen sensor bad. Replaced test drove and found light gone, surging gone, and original throttle response problem gone. Car will now accelarate smoothly from stop.
Old Jul 20, 2007 | 10:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
no0b
To Sensitive Throttle?
Old Jul 20, 2007 | 10:07 PM
Lichen's Avatar
Lichen
I'd be disapointed if my throttle response wasn't sensitve. You're not driving a Yugo! When I touch the pedal, I expect it to moooooove!
Old Jul 20, 2007 | 10:17 PM
94z07fx3's Avatar
94z07fx3
That's true, of course. But the throttle should not be 100% open when the pedal has only traveled 50% of its travel. The throttle should move from almost closed at idle to wide open as the pedal moves from top to bottom. And this goes for the Yugo Koral as well as the Mclaren F1.
Old Jul 20, 2007 | 10:27 PM
Lichen's Avatar
Lichen
Well then, may I suggest that he find another C4 owner and have him drive it and see if it feels normal or crazy. The couple of times that I've had the throttle feel funky, I discovered that the cable had fallen out of that U-shaped cable holder gizmo that's attached to the tb.
