1988 Vette Won't Start
Old Jul 19, 2007 | 02:10 PM
chanchett's Avatar
chanchett
Default 1988 Vette Won't Start
I was shocked to discover yesterday when I came out of work that my 88 corvette would not start. The engine sounds just like it always does when I turn the key, but it just won't catch. I checked a distributor wire, and felt no spark. I replaced the distributor, wires, and spark plugs within the last year.
I don't think it is a fuel issue because I tried to start the car while spraying some starter fluid in the throttle body to see if it at least ran as long as it was getting some fuel.
I bought and replaced the ignition coil last night, but the car still won't start.
Any suggestions would be very helpful.
Old Jul 19, 2007 | 03:28 PM
chanchett's Avatar
chanchett
could there be anything with the Distributor Terminal Board??
Old Jul 19, 2007 | 03:47 PM
woodstock's Avatar
woodstock
If you ain't got a spark, it's more than likely the ignition module.
It needs to be put in with dielectric grease, more than important or it won't last very long, but not too much either. A lot is not always better!
Old Jul 19, 2007 | 04:55 PM
chanchett's Avatar
chanchett
Is the ignition module difficult to install?
Old Jul 19, 2007 | 08:07 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old Jul 19, 2007 | 09:46 PM
chanchett's Avatar
chanchett
I replaced the ignition module it seems to have made no difference, I still get no spark.
Could it be something with an ignition relay? If so, where is that relay located.
thanks
Old Jul 20, 2007 | 08:29 AM
AGENT 86's Avatar
AGENT 86
Did you look at the info I posted ? Follow flow chart C-4A
Old Jul 25, 2007 | 12:35 PM
chanchett's Avatar
chanchett
I ended up having the car towed to a shop because I was getting intimidated by the electrical stuff and didn't want to blow money on changing a bunch of part without result. The car works now! They changed the magnetic pickup lx320. Just thought I'd inform you of the result.
Unfortunately I had to pay a mechanic to change a $30 part for quite a bit more.
To 1988 Vette Won't Start
