accessing headlamp switch
Old Jul 19, 2007 | 06:01 PM
telboy's Avatar
telboy
5th Gear
Default accessing headlamp switch
Need to access the dashboard headlamp switch on my '84.My GM manual is more than vague on how to get to the wiring that connects to the switch.Can I get to this by removing the lower hush panel under the dash, or remove the instrument cluster bezel, or both? Or is there an easier route to gain access?The reason for needing to get to the wiring is I have a pair of supplementary gauges that I want to wire in for the gauge lamps.I figure that if I connect the positive wire to the positive out from the headlamp switch these gauges should light up with the dash lamps when the switch is pulled? Any help greatly appreciated.
Old Jul 19, 2007 | 07:10 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I think you'd be better served connecting to the center dash lamps. the headlamp switch is a real pain in the ***.
Old Jul 19, 2007 | 07:34 PM
cmontel727's Avatar
cmontel727
A good way to access the wiring is to remove the top dash pad. It's held on only with... I believe five screws and clips in the rear. You have to remove the center info console and main dash faceplate. Also have to take **** off the headlight shaft.
This option provides plenty of access to make your changes
Old Jul 19, 2007 | 07:49 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you know what color wire your looking for, I would suggest pulling the lower panel and search the harness leaving the switch. I had to tie into the park lights for my keyless entry, with dash off, that still was the easiest route for me.
Taking the illumination from the radio harness is another option.
Old Jul 19, 2007 | 09:24 PM
Frizlefrak's Avatar
Frizlefrak
The dash pad is simple to remove. Take out the screws and pull it toward you.
To accessing headlamp switch
