Anyone have a link with directions on how to R&R control arms as well as bushings for a C4. Bought one from a guy and he said it had a ball joint loose. Turns out the bushings had worn and he was grinding his control arm on the shock.
Might be easier to just go to a yard (or EBAY) and buy a used one. They only make replacement bushings in urethane, and you'll need to do both sides. 87 down is a different part.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Make sure the inner sleeve is clamped down when torquing the bolt to spec, and the bushing is free to rotate. The ID and sides of the bushing should be lubed, but it's a good idea to lube the OD also. Instead of narrowing the bushing shoulders, I narrowed my suspension parts on a grinder. Most people probably wouldn't be up for this though. It's possible some of the binding issues are due to poor GM tolerances on the aluminum parts. Could also be that the original rubber is just more plyable and doesn't bind up even though it's a bit wider than the inner sleeve.
