rear end question?
Old Nov 1, 2001 | 03:40 PM
fade_to_black's Avatar
fade_to_black
Default rear end question?
My Friends all have 98-2001 T/A WS6's. When they started doing mods and going to the dragstrip, they all seemed to break their rearends. How easy is it for that to happen on my 92 six speed? I am looking into BFG or Nitto D/R. Does my car have a stronger rearend? :cheers:
Old Nov 1, 2001 | 03:50 PM
Goody's Avatar
Goody
Default Re: rear end question? (fade_to_black)
You have the strongest vette diff made to date, the Dana44. It is the same rear end that all M6 vettes have had, even the king ZR-1 :yesnod:
Old Nov 1, 2001 | 04:04 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Still all of them are breakable with the right combination. Usually it is due to the spider gears in the D44 shattering. Does not happen often, but it does happen.
Old Nov 1, 2001 | 04:52 PM
Nathan Plemons's Avatar
Nathan Plemons
From what I've seen on the forum, you'd probably break a u-joint if anything. The dana 44 is strong, they even used it in the dodge viper. It isn't unbreakable, but it's pretty strong anyway.
As for drag radials? Saturday I made 13 passes at the drag strip, 9 of them were on BFG drag radials with me launching at 4100 rpms. I didn't slip the clutch either, just a flat out dump on a new Mcleod clutch. It has held up nicely. I'm only making 9 more pounds of torque than I did stock, so I'm pretty safe. I'm toying with the idea of using some ET Streets this Saturday.
Old Nov 1, 2001 | 05:17 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
If your really worried, I'm working on a direct swap bolt-in 9" ford solid axle for C4 but i't doesn't sound like you need anything that radical yet.
Old Nov 1, 2001 | 06:13 PM
IcemanZ06's Avatar
IcemanZ06
Default Re: rear end question? (mackeyred96)
Mackey,
What are you doing with the Dana44 parts?
I might be interested in a D44 conversion
[Modified by IcemanZ06, 4:13 PM 11/1/2001]
Old Nov 1, 2001 | 06:26 PM
fade_to_black
There is a good side and a bad! I bought the car from a chevy dealership (used car section)....the car is NOT stock. I have beaten my friends 911 turbo twice now (raced up to 130 and shut it down...it is the new 911). When I am at a stop sign and floor it (with ASR off :) )I basically sit there and smoke on street tires (only slow movement forward if pedal is too the floor) which are BFG Comp T/A's. I haven't gone to the track yet, as I only have had it two weeks. The bad news is I have NO idea what the previous owner did.....what sucks is the exhaust is stock and the intake looks stock!!!!! :confused: :confused: :confused: I am just worried about the rearend if I use D/R. Let me know what you think! Thanks....... :cheers:
[Modified by fade_to_black, 4:30 PM 11/1/2001]
Old Nov 1, 2001 | 07:01 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Don't worry about it so much. See you at Ennis Saturday. ;) I will be in a triple white vert going real slow.
Old Nov 1, 2001 | 07:28 PM
fade_to_black
Default Re: rear end question? (Vette92)
see you there..... :D :cheers:
Old Nov 1, 2001 | 08:39 PM
mackeyred96
Default Re: rear end question? (IcemanZ06)
Mackey,
This is a complete swap. Unbolt your entire 44 and bolr in a full 4 link 9"ford solid axel. Best part you'll be able to swap back your 44 no problem.
Like I said it only in the early stages development.
To rear end question?
