Hood susport help
Old Jul 24, 2007 | 01:23 AM
Krazy Glue's Avatar
Krazy Glue
Default Hood susport help
anyone change the scissors hood susport to a gas strut would love to have on any help would be great
Old Jul 24, 2007 | 01:47 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Pretty straight forward as long as you have the two screw holes for the bracket under the driverside upper fenderwell, the bottom bracket bolts to the front lower fenderwell. Won't work on an 84.
Old Jul 24, 2007 | 03:28 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You need to fill out your sig.
I installed one on my 86.Just follow the directions.
The only hard part is conecting it to the holes in the wheel well front.
Old Jul 24, 2007 | 05:39 AM
emo-vet's Avatar
emo-vet
Default i went completely opposite
on my 1991 vette, i fitted up a straight bar r&d racing 84 model camber brace as i removed the air cond and didnt need the curved camber brace.
any way i couldnt then fit my standard power steering resovoir so then i had to buy a 1985 model up right resovoir and fit it further across on the left hand side.
that fixed that problem, but then i could close the hood properly due to the gas strut in the way.
so now i have purchased a scissor hood type prop and will fit that to the right hand side back where the early cars have them.
i guess thats what happen when you start moding things,one problem after the other.
oh well,she will be rite
regards
shae
To Hood susport help
