Hot intake plenum and valve covers. why?
Old Jul 24, 2007 | 10:44 AM
conv90's Avatar
conv90
Default Hot intake plenum and valve covers. why?
I noticed that after the car has stopped after a sprinted run, the engine needs so much hours to cool down (I'm not speaking of oil and coolant temp..).I'm speaking of my superram plenum and valve covers.
After a sprinted run I can't put my hands on the plenum ..too hot.
After 1/2 hours the plenum and the valve covers are still hot but i can put briefly my hands on it.
I always tought that this is normal.
Some days ago I needed to perform a check on the spark plugs.
The car was stopped 1 hours before.
Well, the exhaust (even the part closer to the heads) where not cool, but only warm (I can maintain the hands on it without be burned at all )
if i put my hand on the plenum I have to remove them after some seconds...
Is it normal?
If I let it overnight (say I stopped the engine at night at 1:00 AM ) and I check the temp the morning at 7:00 AM the plenum is almost cool but I can feel it is not completely cooled as others engine parts are .
Old Jul 24, 2007 | 11:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
After effects of heat soak, these cars dont have much ventilation underhood so theres not really anywhere for it to go.
Old Jul 24, 2007 | 12:03 PM
89 Bob L's Avatar
89 Bob L
What you described is not unusual.
Old Jul 24, 2007 | 12:30 PM
vader86's Avatar
vader86
Nowhere for the heat to go.
Old Jul 24, 2007 | 12:35 PM
conv90's Avatar
conv90
What I described is with the hood open!
open or closed the LAST thing that cool down is the intake plenum.
I monitored the IAT temps with various scans and it is only some degrees over the ambient temp, but the surface of the plenum is HOT really Hot!
-Beppe-
Old Jul 24, 2007 | 12:59 PM
Slalom4me's Avatar
Slalom4me
What oil and coolant temperatures display during operating conditions?
Are upper end oil flow restrictors being used in the oil galleys? What
about the push rods, do they limit oil flow? Is there anything about
the valve spring rates or configuration that might cause them to run
hot? Rocker arms?
While I agree with the earlier statements, I know that your engine is
modified.
Old Jul 24, 2007 | 01:22 PM
conv90's Avatar
conv90
hot? Rocker arms?
modified.
coolant at normal operation is never over 200°F
Oil sometimes in the 230-235 range. Normally in 210-220
I never performed prolonged WOT (i have only 550 miles on my new 396)
Oil restrictors? I dont know... I have to ask to Pete K (he made my engine).
Springs are 135 lb open and 365 closed @ 2.030 installed height.
Rockers are the promagnum Comp cams 1.6..
Old Jul 24, 2007 | 01:29 PM
vader86's Avatar
vader86
The materials used in the intake absorb heat and dont dissipate it well.
Old Jul 24, 2007 | 06:00 PM
wayne lowry's Avatar
wayne lowry
That's why guys will ice down the intake between runs at the track of course.
Old Jul 24, 2007 | 06:35 PM
Strick's Avatar
Strick
Here is a suggestion for you, install an electric coolant pump and wire your fans so that you can manually turn them on. When you stop your engine after a hard hot run, just turn on the fans and coolant pump. It's amazing how fast it cools the whole engine down. Just don't run your battery down too far.
To Hot intake plenum and valve covers. why?
