I need to know
Old Jul 25, 2007 | 01:56 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
LT-5! what? oh, sorry...... Any 350 that starts with an L
Old Jul 25, 2007 | 01:58 PM
rickneworleansla's Avatar
rickneworleansla
Originally Posted by CentralCoaster
The early motors might be better suited to NOS with the lower stock compression, but then again you'll need a 100 shot just to keep up with a stock LT4.
I have always been told higher compression is better for N2O and lower is better for FI unless running alki injection. Doesn't the lower intake temp from the nitrous reduce detonation?
Old Jul 25, 2007 | 03:05 PM
dan0617's Avatar
dan0617
You are correct, I think, in the world of engine building. But if you are using nitrous on a stock engine, the high compression ratio and the raised cylinder pressures from the nitrous = cracked pistons. High compression nitrous engines are the biggest power makers, but you need forged pistons, rods, and crank, as well as some serious ring setups.
Old Jul 25, 2007 | 03:08 PM
dan0617's Avatar
dan0617
L98 stock power =
LT1 stock power =
LT4 stock power =
LT5 stock power =
Best way I can sum it up.
Old Jul 25, 2007 | 03:35 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I am by no means an expert on this, but I think given an otherwise stock engine, you could go further with nitrous/FI on the lower compression motor. But then you're starting behind the curve to begin with. Sounds like a wash.
So get the LT1. Factory HP will always be more reliable than aftermarket HP.
Old Jul 25, 2007 | 03:40 PM
CentralCoaster
Originally Posted by dan0617
L98 stock power =
LT1 stock power =
LT4 stock power =
LT5 stock power =
What about L82, L83, L48, etc. And don't forget the boat anchor LG4.
Old Jul 25, 2007 | 03:47 PM
rickneworleansla
I agree for anything above a 150 shot. From what I understand anything below that on a stock engine and it is not necessary. Sorry didn't mean to go off topic. Like Central Coaster said go with the LT1 and stock power is always more reliable as long as it's well maintained.
Old Jul 25, 2007 | 05:09 PM
zr1fred's Avatar
zr1fred
LG4 (Had to look that one up to be sure). Leave it to a California guy to bring that one up.
Old Jul 25, 2007 | 06:59 PM
MightyMike's Avatar
MightyMike
Well, I was thinking of maybe just a 100 shot. Nothing more. Plus I wouldnt use it that often
Too many decisions for my little noodle....
Old Jul 25, 2007 | 07:05 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Buy the newest best condition Corvette you can afford. I had two L98 cars and I do not miss them. The LT1 is better than the L98 just like the LS1 is better than the LT1.
Old Jul 25, 2007 | 07:19 PM
lefoy84's Avatar
lefoy84
Anybody who doesn't vote for the LT-4 is a latent homosexual. With a 160 thermostat. Now back to my life.
Old Jul 25, 2007 | 08:44 PM
mrc24x's Avatar
mrc24x
LS3. end of story. Now go out and sign on the dotted line for 180 months worth of payments.
Old Jul 26, 2007 | 07:59 AM
  #33
dan0617's Avatar
dan0617
Ooh ****....now I'm gonna have to go find 4 or 5 more smileys!!!
Old Jul 26, 2007 | 08:06 AM
  #34
dan0617's Avatar
dan0617
This is good advice, as well as the advice that stock HP is more reliable than aftermarket HP. The more stock HP, the more the car is built to handle. It depends on budget. If you have a small budget to start but can put money in it over time, buy a L98, or even a C3 if the budget is really small. You will not be unhappy with any Corvette. If you have some dough to work with, buy the LT1, or step up to the LT4. ZR1 is the way to go if you want a C4 and are willing to put out a good deal of money. Then there is the C5, and......
I think just about any stock Corvette from any year could handle a 100 shot. Not sure if the LT5 engine can, but you will need a 100 shot on any other stock C4 just to keep up with the LT5!!!
Old Jul 26, 2007 | 08:11 AM
  #35
dan0617's Avatar
dan0617
So, wanting a ZR1 makes me a latent homosexual? Then what am I to do with all these women hanging all over my L98? I was hoping to get more women hanging on a ZR1 if I ever get one. You mean to tell me I'll have a bunch of homosexuals hanging on it? Sounds like I better stay with the L98!!!!
