Stumble
Old Jul 25, 2007 | 08:16 AM
1988roadster's Avatar
1988roadster
Default Stumble
My 88 has developed a stumble when accelerating at any speed. Anyone have an idea what can cause this?
Old Jul 25, 2007 | 09:12 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check the condition of your plug and coil wires. Are they O.E.M? More than 60,000 miles? You might just have a bad case of the electrical creepycrawlies....
Old Jul 25, 2007 | 10:57 AM
trackman44's Avatar
trackman44
Default low fuel pressure
Check fuel pressure, you might have a dirty sock (in tank filter), clogged fuel filter or clogged injectors. Also fuel pump could be on its last legs. Pour fuel injector cleaner in the tank before fill up and see if that improves acceleration.
Old Jul 25, 2007 | 11:05 AM
Rick Williams's Avatar
Rick Williams
Check your MAF sensors..I had two on my 87..behind the battery..They are not expensive and solved the same problem you described ..
Stay safe
Rick
To Stumble
