Stumble, lean condition after work
Old Jul 26, 2007 | 09:34 AM
trinitydigital's Avatar
trinitydigital
Default Stumble, lean condition after work
I posted in general also.I have been desperately trying to get my car to run well, efficient. I had the engine overhauled in January and started replacing every thing I could see. We just replaced egr valve, fuel pressure regulator (stock ac delco)and injectors (denso #22lbs.)As soon as I fired it up, it has developed a significant stumble on acceleration and when scanned it is showing a lean condition (121 integrator ) Fuel pressure is correct, injectors all firing (noid light test) all pulsing exactly the same.
It has new Taylor wires, new AC Delco plugs,cap,rotor, coil, k&n air filter, new fuel pump, etc.
The tech who checked it says it may be a bent push rod or a broken valve spring and even mentioned a bad cam. I am hoping for some wisdom from the brilliant members here for help. As always, thank you all in advance.
Old Jul 26, 2007 | 09:49 AM
conv90's Avatar
conv90
Even if you are speaking of BLM (instead of integrator), the 121 is not a lean number. it's a rich value.
This does NOT means the car is actually run rich... this means that your ECM is slightly correcting a rich condition. You are at 14.7 . period.
This is not a fuel related (too much or too little fuel) problem (part throttle spaeaking).
WOT and heavy accelerations involving power enrichment routines in the chip are another story...
I don't see on your list the fuel filter.
-Beppe-
Old Jul 26, 2007 | 10:13 AM
trinitydigital
Default Fuel filter
That fuel filter was done also. As I noted: This started after the fuel pressure regulator, egr valve and injectors were changed. The BLM and integrator stuff is over my head. I'm trying to learn. I need help.
Old Jul 26, 2007 | 11:19 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Simply cause the BLM says its at 121 and its correcting what it thinks is a rich mix, doesnt mean it is correcting a rich mix. If the O2 sensor is buggered it could be telling the ECM its rich whether it is or not.
Have a look at the MAF sensor and see if the wire inside it is dirty.
Old Jul 26, 2007 | 11:28 AM
trinitydigital
Default MAF Looks good
MAF Looks good, clean. My concern is the stumble on acceleration. Not to mention the doom and gloom the tech had for me about camshaft, valve spring or bent rod.
Old Jul 26, 2007 | 11:39 AM
Casethecorvetteman
Get them to stick a wide band on it to check the integrity of the O2 sensor.
Check that the knock sensor is working as it should
Check the compression
CO test the coolant
Does it do this when its stone cold?
Does it do it in open loop and closed loop or just closed loop?
Check the TPS
Check the ignition control module
Check all the grounds
Old Jul 26, 2007 | 11:41 AM
Demonic85's Avatar
Demonic85
If the valvetrain was messed up it would be fairly obvious. It would sound somewhat lopey if anything was bent or worn out. Not so much the springs though, you'd probably have to take them out to find a broken one.
Old Jul 26, 2007 | 11:54 AM
Casethecorvetteman
If a spring was broken it would probably be ticking like buggery.
Old Jul 26, 2007 | 11:55 AM
trinitydigital
Default Answers
CO test the coolant
Check the TPS
Compression was good.
CO test coolant? No.
Yes it does it cold.
Both open and closed loop.
What check can I do on TPS?
aHH, Ignition control module. I can do that.
Grounds? Wow. From what I can tell there are hundreds of them.
Thanks for the leads. Truely.
Old Jul 26, 2007 | 12:13 PM
Casethecorvetteman
What do you mean "CO test coolant? No."? Are you saying you did it and you had no combustion gases in your coolant? Or are you saying you dont want to test it?
There are quite a few grounds, your car isnt working properly so check them all.
Put a volt meter on the TPS and make sure its within spec from closed throttle to wode open throttle. It should start at 0.54 volts and move smoothly up to somewhere around 4.5-5 volts at wide open throttle.
If its not at 0.54 volts when the throttle plates are closed then adjust it til it is. It should be no higher than 0.6 at closed throttle.
What about the knock sensor? Did you test that to be sure its working?
While youre at it, check the timing as well, it should be about 6* to 8* advanced with the ESC wire disconnected.
Old Jul 26, 2007 | 12:36 PM
trinitydigital
Default my mistake
(CO in coolant) I meant that I hadn't checked it yet. That would lead to a bad head gasket? As I noted, this thing started when I changed EGR, fuel pressure regulator and injectors.
Old Jul 26, 2007 | 12:41 PM
Casethecorvetteman
Not always, it could mean a cracked head or cracked block.
The fact it only came up when you changed what you did may very well be coincidental, and you shouldnt leave anything to chance, everything you check as working correctly is another thing you can cross off the list as a possibility
To Stumble, lean condition after work
