open longtubes
Old Jul 26, 2007 | 10:19 PM
92lt1vet's Avatar
92lt1vet
Default open longtubes
would it be ok to track my 92 lt1 vet with open longtubes? or would it run better with the borla and the x pipe? thanks mike
Old Jul 26, 2007 | 10:57 PM
STL94LT1's Avatar
STL94LT1
You'll need the car tuned for open headers. I would just stick to the x-pipe and cat back.
Old Jul 26, 2007 | 11:03 PM
all show and more go's Avatar
Old Jul 27, 2007 | 12:18 PM
rickneworleansla's Avatar
rickneworleansla
People do it with exhaust cutouts so I don't see why not. Do you mean ending the exhaust at the back of the headers? Messing with O2's you would need a tune. If any air comes in from the back it could cause it to run rich. Exhaust heat may be an issue also.
Old Jul 27, 2007 | 08:46 PM
92lt1vet's Avatar
92lt1vet
yes rick its going to be just open headers no exhaust at all
Old Jul 27, 2007 | 08:54 PM
Scott-89's Avatar
Scott-89
I'm not sure how it would affect the O2 sensor/s. I would at least have some turn-downs put on it to direct the heat towards the ground.
Old Jul 27, 2007 | 09:00 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
You can but I'm not sure you will want to drive around like that. I had to drive mine to the exhaust shop that way and it was LOUD. Now I like loud exhausts but there is now way you could function on the street everyday like this. Race track is a different story
Like the others have said it is like running the cut outs
Oh, I did I mention the smell? Running a full exhaust sans the cats will give you some strong odor. If you run open headers the inside of the car is going to smell like a gas can!!
Old Jul 27, 2007 | 09:28 PM
rodj's Avatar
rodj
I'm in a similar situation
For my drag only car was going to remake the LT's where they neck down to 2.5" and build a true 3" collector 12 -14" long.
Is that going to be long enough to prevent O2 errors from dilution at idle?
Alternative is to extend 3" pipe all the way to turn down at rear of trans.
To open longtubes
