how well do c4's hook up?
Old Jul 28, 2007 | 09:53 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I have gotten a 1.78 short time on my Nitto DR's but my car only makes 275 rwhp so I won't do much better than that...
Old Jul 29, 2007 | 10:26 PM
hookedup's Avatar
hookedup
Originally Posted by rickreeves1
Ask them how much they spent on breaking parts.
I've never been brave enough, or is it stupid enough, to add up all that carnage but it did go 1.34 dead hooked when it didn't break
BTW, the last year I had the D44, I broke the rear 5 times
Hope you guys have better luck,
Dave
Old Jul 29, 2007 | 11:20 PM
pr0zac's Avatar
pr0zac
Originally Posted by 93 ragtop
They hook (ET Streets) extremely well on a C-4, at least for me. If I understand what you are saying, that the tire could wrinkle slightly different on the inside vs the outside, that may be part of it.
yes that was my reasoning
Originally Posted by rodj
The ET streets get their great traction from the soft compound , not from sidewall quish like a true slick.
My observations have never seen the sidewall distort enough to compensate for the outside lift during camber change.After a run my tires show visible marks on the inner half with nothing on the outer.
The camber change on launch can be dialed out by changing the chamber setting but then it would be wrong for stret use.
well it was just a thought.. and i was using et streets as an example of a tire with a wrinkle wall.. just wondering if have you played with tire pressure? i know with my camaro and et streets i could wrinkle the tires quite a bit to the point where the rims were very close to the pavement but that is apples and oranges and just thought if you used a tire with a bit more sidewall and around 15psi you may acheive a better contact pad in our cars.. but i don't really care to put the effort in that much... and as i said.. just a thought..
Old Jul 29, 2007 | 11:54 PM
Trog's Avatar
Trog
You can do things like the DRM extragrip w/ relocated camber rods (less camber change during squat) & reduce the toe??
Old Jul 30, 2007 | 12:25 AM
imputor's Avatar
imputor
my first time dragging on goodyear eagle HP ultra 285's i had a best 60' of 1.833s. Like some of the others a few spins then hook with a good chirp into second.
Old Jul 30, 2007 | 09:43 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Not me. Ask them how much they spent on breaking parts. Ok maybe just a little jealous.
Repeat after me: "Race it, break it, fix it, race it"....I broke my Dana 36 about 4 years ago (no big surprise) and put in a Dana 44...over 600 passes since then without any breakage of anything...
The old story will never change...Speed costs money so how fast do you want to go?...the faster you go the more stuff breaks...same old, same old...
