Hard brake pedal solution, finally!!
Your car does have a proportioning, it's accomplished by the combination valve in the master cylinder. It reduces rear line pressure the harder the brakes are pushed, and the weight transfers towards the front tires. If you removed the combination valve, you'd probably lock up your rear brakes first.
There is no need to get uptight - I was not trying to pick at what you said, but using the wrong terminology confuses issues when people are trying to understand things.
The only point at which leverage is gained or lost in the system is through the brake peddle pivot point. smaller piston = hydraudic advantage = more PSI (pressure).
I was referring to an aftermarket proportioning valve that allows finer tuning of the system to get a better balance - with the springs that is in there you don't have a lot of ability to fine tune with it - all you can do is change it to something else that may or may not be adequate.
We put one of these on my fathers chevelle and it helped out quite a bit, but he had drums in the back and disks up front. If the MC doesn't help mine - I might throw one of them inline and see what results it yields.
If you want to control the rear line pressure with a prop valve, then make sure to remove the combination valve entirely and cap off the warning sensor hole with a metal plug. It also isn't the solution for everyone.
On my setup for example, I'd actually need to put more pressure to the rear lines than the fronts, even during maximum braking. This is because the larger front rotors and pistons can do way more with the same amount of line pressure.
In a straight line, at -1 G, the rear brakes can still do 35% of the braking. Obviously this wouldn't be safe in a turn or on uneven road surfaces. GM however, uses only about 20% of the rear brake in the early cars at max braking. They're leaving a lot on the table.
have the people that have been experiencing problem tried changing their rubber lines to the calipers? I do recall reading in here somewhere that people went to stainless lines with no improvement......mine are just the stock rubbers, so that is something to consider.
What are the J55 calipers? Where did they come from (new vettes?), I am not familiar with their name - can you explain.....and will they fit a 15" wheel?
PS: Case I got to visit the Holden Austalia plant last year at this time and got to see some of the "secret" cars they were going to be launching. We make internal engine component for the cars you mentioned above.
Very beautiful country you have - loved everything EXCEPT the plane ride. 28 hours of fly time - ONE WAY! They had to practically drag me back on the plane for the ride home. If I did not sink like a rock in water; I was considering a boat home - but that would have even taken longer. You need to float a little closer thisa-way!
Did you pay your speeding fine before you left??
The J55 is a 13" front brake package, as apposed to the standard 12" JL9s. Both calipers take the exact same pads. I seriously doubt youll fit them under a 15" wheel, but ive never looked into it.
...what good will that do as it (spring) is only a band-aide for an existing problem....gm doesn't put that spring in there from the factory!...
...abs has little to do with braking force as it only comes into play when different speeds (skid) are detected at the wheels and the abs modulates the brakes to attempt to keep the car straight....
the brakes were always a sore spot with me, and I gradually figured that the booster was under engineered for the car.
I was planning on maybe stepping up to a dual piston caliper.
Now, I may play with the electronics a little to see if it's something else.
Come to think of it, my rear pads seem to last forever.
Maybe the ABS has sufficiently shut off the fluid to the rears, and that's why it is hard to stop, and the pads last a long time.
Sigh.......another area that The General kept a secret that I have to unlock.........
