Hard brake pedal solution, finally!!
Old Sep 2, 2007 | 05:02 PM
  #141
Da Mail Man's Avatar
Da Mail Man
....ttt......
Old Sep 2, 2007 | 05:21 PM
  #142
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by Casethecorvetteman
It will need a different reservior on the later models for the connection of the ABS prime pipe.
Have a pic?
Old Sep 2, 2007 | 08:48 PM
  #143
pcolt94's Avatar
pcolt94
Originally Posted by CentralCoaster
Have a pic?
I think this fits 92 - 94, definitly 94. The pipe outlet from the reservior goes down to the ABS (reservior) pump.
Sorry for the dirt
Old Sep 2, 2007 | 09:19 PM
  #144
Da Mail Man
.......would an 86-87 single reservoir work on an 88?...would love to test one...
Old Sep 3, 2007 | 12:51 AM
  #145
CentralCoaster
I've got both on my shelf and I think it would fit just fine.
The front line has to move back about 2" though, if its flexible enough.
I'd post the difference in piston sizes, but I can't seem to find my damn calipers.
Old Sep 3, 2007 | 04:43 AM
  #146
Casethecorvetteman's Avatar
Casethecorvetteman
Have a pic?
No, but he does:
Sorry for the dirt
That one right there is straight off a 94, and as Pcolt said, the outlet on the left of the reservior is for the ABS prime pipe
Old Sep 3, 2007 | 04:55 AM
  #147
CentralCoaster
So why don't the early ABS cars have that?
What does that connection do? I assume it lets the ABS circulate fluid back to the reservoir. So if your car didn't come with this.... is it a bitch to get air out of the ABS?
Old Sep 3, 2007 | 07:38 AM
  #148
Fastmax32168's Avatar
Fastmax32168
If you are looking to increase your leverage on the brakes and you can fab, a cheap and easy way would be to cut the brake pedal lever and add an inch or so in the middle of it. The pedal is more than high enough to accomplish this without ending up with an awkward feel to it and cost would be virtually nothing. This would give you about a 10% increase in leverage on the master. How much it would help...well I guess somebody would need to try it to tell.
Roy
Old Sep 3, 2007 | 08:04 AM
  #149
Casethecorvetteman
Earlier systems are not as advanced. I can only assume it is something that came along as in improvement or something the ASR system required to be more effective.
Bleeding the prime pipe is a piece of ****, its a one man job. I looked at my mum's Mercedes Benz in this area recently, it has not got the prime pipe, but it has no traction control, it does have the connection at the reservior. The other C class Benz i drove before i got that one for my mum did have traction control, and i remember it having 3 lines going into the ABS unit, however i didnt look to see where the 3rd was connected. It was an input, cause the 4 outputs were all clearly marked for each wheel and on the other side of the unit.
Old Sep 8, 2007 | 06:44 PM
  #150
Da Mail Man
.....ttt
Old Sep 8, 2007 | 08:09 PM
  #151
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Not a good weekend for me to have time to play with my master cylinder - so my test is going to have to wait. All I can tell you is the master cylinder I ordered from Strange is about 3 times the mass that the stock one is - and not in the bowl area, but in the piston/housing area...therefore there might be something there to say for what we are seeing with the stock setup. Its almost laughable the size difference.
The proof will be in the performance through.
Old Sep 8, 2007 | 08:13 PM
  #152
Da Mail Man
.....led zepplin said it; "the song remains the same"...thinking about picking up a single resovoir to see what happens but, i can't see it making any difference since i have a know good dual working unit....
Old Sep 9, 2007 | 01:02 AM
  #153
Casethecorvetteman
The number of reserviors wont make any difference mate.
Old Sep 9, 2007 | 07:27 AM
  #154
Da Mail Man
......yeah, i really didn't think it would....
Old Sep 9, 2007 | 09:17 AM
  #155
rick lambert's Avatar
rick lambert
Interesting post to say the least , I have nothing to add, my 87 seems to stop quite nicely. What I'm really curious about is Cuisinart and his "loud pop", obviously we can throw out a brake line bursting, so what's left? I can only think of 2 things, a caliper piston or a valve....and now he has good brakes? I'm just thinking here (or maybe not), but it seems to me if alot of you are experiencing hard braking with mostly new components (pads, hoses, boosters, MCs, rotors, calipers) then I'd be taking a careful look at the ABS system malfunctioning....just my 2 cents worth...probably not worth 2 cents
Old Sep 9, 2007 | 09:36 AM
  #156
cv67's Avatar
cv67
St. Jude Donor '05
Rick, good to see youre back, hope youre doing Ok.
No idea what the "pop" was, wasnt a good noise though.
Old Sep 9, 2007 | 11:46 AM
  #157
salty104's Avatar
salty104
4th Gear
Default confused with my brakes
New to forum. love it. I have an 88 aniv. just changed frnt calipers when i bled the right frnt, no problem, plenty of fluid, when i did the left frnt no fluid at caliper. seperated rubber line @ steel line no fluid.This is my first vette with ABS, could use some help. This is my 9th vette & i have never had this problem before.
Thank's in advance
Mike:
To Hard brake pedal solution, finally!!
Old Sep 9, 2007 | 03:20 PM
  #158
Da Mail Man
Thank's in advance
Mike:
.....welcome to the jungle......
Old Sep 9, 2007 | 03:31 PM
  #159
CentralCoaster
Loud pop?
Maybe it was the combo valve being shot to the front or back of the m/c due to air in one of the circuits giving a pressure imbalance.
Old Sep 9, 2007 | 06:03 PM
  #160
Da Mail Man
Originally Posted by Mike_88Z51
Mail Man, I can understand your frustration. If you have an 88 and you don't know if the ABS kicked in, then your ABS wasn't working correctly. On my 88 and my brother's 89 (same ABS system, non-Z51, stock brakes) when the ABS kicks in you KNOW IT. The ABS activation results in a fast bunch of sledgehammer pulses as the wheels start to lock at max traction and then the ABS releases and repeats. When I do an ABS panic stop test from 50 mph I don't need to check the ABS light, as the car feels like it is being b*tch-slapped by Superman.
***i had given this some thought the other day and YES, the abs did activate as i remember now hearing that sledge-hammer/anvil noise-effect...i went back to where this occured and originally i thought that there was rough pavement but, it was a recently paved road....still, i needed a leg like a power lifter to even have a chance at stopping the car (which i barely did)...
