Diagnosing my 86
Old Jul 30, 2007 | 09:36 PM
senorv47's Avatar
senorv47
Default Diagnosing my 86
Does anyone know the the circled procedure is on the image below:
It's a Distributor bypass. I have gone down this page step by step and I'm at that point for hard starting. Besides the fuel pump (which I do has 42 lbs of fuel pressure with the pressure tester) I need to finish this procedure.
any Ideas out there?
Thanks in advance
Old Jul 31, 2007 | 08:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I believe they are referring to the EST wire and it's connector located to the inward side of brake booster. Single tan/black stripe wire.
Old Jul 31, 2007 | 09:15 AM
CFI-EFI's Avatar
CFI-EFI
That is the same wire you disconnect to check/set your base ignition timing.
RACE ON!!!
To Diagnosing my 86
