Wow. Just....wow.
Old Jul 30, 2007 | 10:42 PM
ScaryFast's Avatar
ScaryFast
Default Wow. Just....wow.
LT1 guys, see anything strange in this picture?
How about now?
Yessir, that's correct. The accessory bracket snapped at the top bolt. It was all barely held together by the belt. I'm lucky it didn't come apart completely and make a complete mess of my entire engine, hood, and me.
The opti is toast, I don't know if this is the cause of it or not. I'm not sure how, but it seems quite coincidental that both failed at the same time.
Old Jul 30, 2007 | 10:47 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Wow, you know I've personally broken a bunch of PS mounts off those accesory brackets. I guess hi revs???
Old Jul 30, 2007 | 11:11 PM
ScaryFast's Avatar
ScaryFast
The car died on the straightaway, I don't know for sure when the bracket actually broke. Certainly not before Saturday as I had it apart until Friday doing other work. You set the limit at 6700, I hit it occasionally but try to shift at about 6500. I guess that's a lot higher than the 5500 stock, and I'm above 3500 all day.
So do you know of a better replacement or a way to strengthen it?
Old Jul 30, 2007 | 11:17 PM
aboatguy's Avatar
aboatguy
Wow! if revs are doing it I guess I'll be looking for an underdrive damper, is the ASP945803 any good?
(It's 22% underdrive so an engine was running at 7K it would drive the accessories at the same belt speed as a stock engine going at 5460 right?)
Old Jul 30, 2007 | 11:21 PM
96GS#007's Avatar
96GS#007
I've never seen that happen before! Vibration induced fatigue from the high rpms?
I'm saving for a C6Z, but more and more I'm thinking an '01 or '02 C5Z would be a nice gap filler for a few years. I hate to say it but it's getting to the point that C4s just take waaay too much effort to put on a road course (and be able to run with the big dogs) short of turning it into a full-up gutted track car / spending Z money. It's the little stuff driving me insane...alternator a couple months ago. High pressure ps line (DRM ss braided line) a couple weeks ago. What's going to happen this weekend, I have no idea?!
Old Jul 31, 2007 | 08:34 AM
Topload's Avatar
Topload
96GS#007.....if you let up just a little on how hard you're punishing that poor GS - it might last a little longer between repairs
Old Jul 31, 2007 | 09:45 AM
Strick's Avatar
Strick
Bring it to a precission welder and beef it up a little.
Old Jul 31, 2007 | 09:48 AM
ScaryFast's Avatar
ScaryFast
I hear that! Just to keep it running within the last month I've had to do:
both rear wheel bearings (wear item)
right rear suspension knuckle (failure)
accessory bracket (failure)
fire damage (bad luck)
optispark (failure)
exhaust (failure, but it's aftermarket)
My competition brings their C5Z's to the track, put up similar lap times with the AC on and radio blasting, and go home. I gather up a group of people and push my damn car up on the trailer. Then I spend every night until 2 am fixing it while they cruise around town in their warranteed cars
Old Jul 31, 2007 | 09:52 AM
vader86's Avatar
vader86
Now that is surprising.....
Old Jul 31, 2007 | 09:54 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Old Jul 31, 2007 | 10:11 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
Haven't seen that one before. I'd just put another one on there and call it a day. If if happens again, then I'd give it sme more attention.
Old Aug 4, 2007 | 01:21 AM
96GS#007's Avatar
96GS#007
In the post above I asked the rhetorical question "what's going to happen this weekend...?"
2nd session out on the track I got my answer.... wheel bearing
Old Aug 4, 2007 | 09:04 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Is there any particular reason you're not using the factory flanged bolt in that location? Are the washers you're using there hardened? How many of the rear accessory supports are still in place?
Old Aug 4, 2007 | 09:11 AM
Road Agent's Avatar
Road Agent
Excellent question!
Old Aug 4, 2007 | 10:52 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default bracket
you obviously have a vibration problem or a bent pulley, or something in that realm. The best thing to do for the broken bracket in my opinion is:
1. obtain a dial indicator with the little wheel on the end of the stick,
(I think they make different feet for it)
2. do a runout on each pulley.
3. do a runout on your powersteering pump shaft.
4. Check each pulley before and after the powersteering for cracks
5. I would (don't laugh) try a modified frisbee to see if your harmonics might be affected by the belt screaming around the pulleys faster than it's design speed.
6. see if there's an opportunity to change out your belt tensioner for either a new one, or one with extremely low time. It could be that yours has crud in the pivot area, and the spring cannot react fast enough due to high friction losses.
7. try using something called dye penetrant on your brackets after your last race (every time) to determine the number of hours you are going to get out of a bracket, and about an hour before you suspect failure, change the bracket, and cut it up with a hacksaw in some manor to alert you that that bracket has about reached it's racing life.
8. try changing the pulley diameters on different things to ascertain if the current frequency of speed vs pulley diameter isn't setting up a belt flex motion that's resonating at the bracket's destruction frequency.
other than that, I have no clue
Old Aug 4, 2007 | 11:05 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
optispark (failure)
Geez Scary... that sucks. As far as the competitiveness of the C4, I think you still got a good car there. When I was doing autox, I saw some pretty serious guys do VERY well with C4 cars.
Old Aug 4, 2007 | 08:46 PM
ScaryFast's Avatar
ScaryFast
Mostly becaue I didn't know they weren't...guess I'll be making a trip to the dealership.
Additional information - upon taking the bracket off I noticed that there were only two bolts. This didn't seem odd until I looked into my FSM for torque specs and saw three. The middle bolt under the tensioner pulley was gone. I can't see how it could have come out due to it's position (trapped under the pulley) so at some point it didn't get put back in.
That could very well have caused extreme loading on the upper attachment which caused it to fail over time.
To Wow. Just....wow.
Old Aug 4, 2007 | 08:49 PM
ScaryFast's Avatar
ScaryFast
Good suggestions, thanks. The AC replacement pulley was slightly farther back than the WP and Alternator pulley, putting a cantelevered rearward load on the upper corner. Another possible contributing factor.
I put it back in position and will keep an eye on it.
Old Aug 4, 2007 | 08:50 PM
ScaryFast's Avatar
ScaryFast
Lucky you...at least your car didn't catch on fire.
Old Aug 4, 2007 | 11:27 PM
BlackC6LS3's Avatar
BlackC6LS3
Are you by any chance running FMRFST's AC Delete Bracket? If so I have found that you can either shim it with a washer to get the belt perfect, or in my case where I needed a smaller pulley, it came with an insert that I had to drill to fit diameter wise, but is also shimmed the pulley into the perfect spot.
