Which spark plug and what gap?
Jul 30, 2007 | 11:53 PM
Acct Suspended 11 JUL 2025 by request
xyz
Jul 31, 2007 | 07:12 AM
Jul 31, 2007 | 08:34 AM
the 350 Vortec heads typically call for Autolite 605`s, gapped at .060"
that plug gap is excessive, IMO.
try Autolite 103`s, gapped at .030-.035" thats the gap the 86 vette used. (.035")
the smaller the gap, the better, for eliminating "flashover"...
Jul 31, 2007 | 08:35 AM
This is from the GM parts direct website for a crate motor with vortec heads.
R44TS Gap @ .045 (300 HP 350)
41-932 Gap @ .060 (330 Hp 350)
R44LTS Gap @ .045 (330 Hp 350)
Rapid Fire #8 @ .035
Jul 31, 2007 | 08:40 AM
an R44TS is not correct for Vortec heads. that plug is for older (short reach threads) SBC`s.
Jul 31, 2007 | 09:21 AM
Sorry for the typo in my original post
xyz
Jul 31, 2007 | 12:44 PM
the 103`s are a little colder, so if your engine is runing too rich, you might have issues with fouling.
but they are listed as replacements on some GM`s from the 80`s-90`s, and lots of Ford models since the 70`s, all the way up to today..
104`s will fit too, but they are typially designed to gap at about .045"...
Jul 31, 2007 | 12:50 PM
BigLee, you are correct. The R44TS is what the parts store gave me and I had to take them back. I believe the R44LTS is the long reach? Popular hot rodding used the Autolite 103's in their vortec buildup. Mine are gapped at .035 (using small cap dist. with external coil)
Jul 31, 2007 | 02:34 PM
i`m not certain, but the R44LTS may not work either...
IIRC, that plug is for L98/LT1 aluminum head engines.
they had the long threads, but use a flat gasket seat, instead of
the tapered seat, like Vortec, and newer engines.
Jul 31, 2007 | 10:19 PM
I reset the gap at 0.040"
xyz
350 ,
605 ,
805 ,
autolite ,
c4 ,
corvette ,
gap ,
head ,
heads ,
installing ,
l98 ,
plug ,
plugs ,
sbc ,
spark ,
vortec
