L98 Cam
Old Jul 31, 2007 | 03:31 AM
rube1975's Avatar
rube1975
Default L98 Cam
I know that there are a ton of threads about this but they are not really what I am looking for.
I have a 1989 L98 with (http://www.melroseheaders.com/produc...ystems/c-4.php) exhaust, and will be putting 1.6 rockers. what I want is a loud cam with improved power with stock heads. if necessary I may port some runners to match the bigger flow.
PS It may be overall benefiting if someone has some info as to the decrypting a cam spec.
Old Jul 31, 2007 | 09:40 AM
vader86's Avatar
vader86
We need more information. If you want a lopey camshaft, you will need far more than ported runners to feed it.
Read my website
Old Jul 31, 2007 | 11:00 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you have a stick you could go with something like a TPiS ZZ-409 and reinforce your valvetrain. Your intake and heads will hold down performance until you go to a better flowing setup.
Old Jul 31, 2007 | 11:10 AM
CFI-EFI's Avatar
CFI-EFI
LOUD???
RACE ON!!!
Old Jul 31, 2007 | 12:57 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default cams
cams don't make noise unless they are losing a lobe, and then you can hear them tick tick tick.
exhaust mufflers are the noise quieter, or enabler.
cams also make the engine noticeably rough idling, and certain ones can kill all your low speed torque.
hint hint
Old Jul 31, 2007 | 04:47 PM
shotchkiss's Avatar
shotchkiss
GM ZZ4 cam and valvesprings should work fine, cheap and easy to find.
Old Jul 31, 2007 | 08:45 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Read my website
And a good tune (chip) to go with it. If you are looking for that lopey sound at idle, you could just pull off a spark plug wire .
Old Jul 31, 2007 | 10:05 PM
anesthes's Avatar
anesthes
hint hint
So your saying if I remove my 306 degree cam and install a factory 195 or so degree cam, my exhaust won't get less noisy? hah!
Every 'kid' in the world who does exhaust mods, find out sometime later on when they swap the cam how much louder + faster the car gets. And the old saying goes, 'the faster it is the more noise it makes'. Its true.
I think this is what the original poster meant. More 'overlap' little more tone. Cam will do that.
Of course, his TPI intake and 113 heads aren't gonna help much with his power goals.
-- Joe
To L98 Cam
