my inside lights wont go out they started by flickering then 2 days later wont go out at all checked the 3 switches 2 door and back window all work fine need help
Maybe fill out your profile so we know what year car you've got.
On my '93 there is a little slider switch by the light switch. If you push that up past a little detent, the interior lights stay on. Maybe your switch got bumped on, or there is a problem with the switch itself.
Could be your courtesy light timer is toast. There were some good threads on this with bypass info and repair info. Use the advanced search of archives on this subject.
Here is it's location http://members.shaw.ca/agent86/Court...20Location.pdf
